Всем привет. Купил недавно EasyDiag 2.0  на авито.  но никаких марок и eobd  нет. какую покупать марку чтобы сделать отлом. Хотелось бы активировать все марки
6 минут назад, ilnur1996 сказал:
Интересно, почем сейчас "пустышки"????
LANDROVER V33.60 (RU) под лицензию EOBD22.53 для Easydiag 2.0
1. Summary
Added “Read Data Stream”functions for 13 models of Land Rover and Jaguar since 2017;
added health diagnosis function under quick test and optimized "Read Vehicle Information".
2. New Functions
1) Added “Read Data Stream”functions for Land Rover and Jaguar models since 2017
(specific models are: 2017 Land Rover Discovery, 2017 Land Rover Range Rover, 2017
Land Rover Range Rover Sport, 2018 Land Rover Range Rover Evoque, 2018 Land Rover
Range Rover Evoque II, 2018 Land Rover Discovery Sport, 2018 Land Rover Range Rover
Velar, 2018 Jaguar F-TYPE, 2018 Jaguar XF, 2018 Jaguar XE, 2018 Jaguar F-Pace, 2018
Jaguar E-Pace and 2019 Jaguar I-PACE).
2) Added health diagnosis function under quick test.
3. Optimized Functions
Optimized "Read Vehicle Information" for Land Rover and Jaguar models since 2017.
4. Fixed Bugs
1) Fixed the failure to execute Key verification function on 2014 Discovery and 2016 Range
Rover models.
2) Fixed the failure to perform motor replacement function on 2011 Range Rover Sport.
3) Fixed the failure to carry out absolution position sensor replacement function on 2010
Discovery.
4) Fixed the failure to implement steering column calibration function on 2003 S-TYPE.
LANDROVER.txt
10 часов назад, algirdassg сказал:
Правлены под EasyDiag 2.0:
  Скрыть контент
+---AUDI----V28.55 +---Division V28.55  +---BMW---V50.30  +---DAEWOO --V27.03  +---DFXK---V13.73 +---HONDA---V47.30  +---HYUNDAI ---V50.61  +---INDIANMAHINDRA ---V12.81
+---KIA---V44.60  +---MAZDA---V41.70  +---MITSUBISHI  ---V33.10  +---NISSAN ---V44.40  +---PEUGEOT  ---V43.60  +---PORSCHE  ---V23.60  +---RENAULT ---V42.92
+---SAICROEWE ---V12.65  +---SKODA  ---V28.16  +---Division V28.16  +---TOYOTA ---V49.40  +---USAFORD ---V47.60
Положить свой  отлом
Ссылка на 1 дeнь
Пароль :
20jvwhg;uWHG-/*/*BGUygtotsi321574797JBHGOYRTOSR-**-**/';[][pjgytgt20
 https://dropmefiles.com/GmDab
При попытке разархивировать...Ошибка Контрольной Суммы
убери пароль
пароль не подходит
57 минут назад, litmak сказал:
убери пароль
пароль не подходит
Ого какие приказы.   Это в место спасибо .   А может научитесь компьютером пользоваться ?
53 минуты назад, litmak сказал:
убери пароль
пароль не подходит
Разархивировать нужно на компьютере в приложении 7zip.
Пароль правильный, проверенно!
1 час назад, litmak сказал:
убери пароль
пароль не подходит
Ну уже не выдержал! Наглость не имеет пределов! Вам кто-то что-то должен? Если вы не можете сделать простую операцию, зачем вам это? Как вы будете заниматься диагностикой?
2 минуты назад, janik22 сказал:
Где наглость?   если у меня 7Zip при распаковке пишет Пароль не верен,  либо я копировать не умею, либо хз, могу вставить скрин
1 минуту назад, litmak сказал:
Ищите у себя! У всех прекрасно распаковывается! И автору не забудьте сказать спасибо!
1 минуту назад, janik22 сказал:
распаковывается второй его архив. а первый
 нет
4 минуты назад, janik22 сказал:
проверь ,потом отпишись
Хотя сорян..толи мышка тупила толи ещё что.. видимо пробел был лишний.. распаковал..можно снесли посты
Division VW 28.56  (Только Division)
https://dropmefiles.com/AHkmr
Ссылка на 7 д.
Пароль :
Division
При копировании пароля реально может быть проблема. У меня второй архив не открывался. Нужно после ввода пароля прогнать курсор по знакам стрелками вправо-влево. В некоторых местах, при нажатии на стрелку, курсор не двинется. Этот как-бы пробел нужно удалить. Визуально ни чего не меняется, но архиватор начинает принимать пароль. А можно просто ввести пароль руками, но это не спортивно😀
Подскажите пожайлуста у меня открыты марки через EOBD22.48, можно ли заливать марки от  EOBD22.53.И как можно перейти на EOBD22.53?Спасибо
47 минут назад, eek163 сказал:
Все  для лаунч 2.0 берут марки от еобд 22.53. Берите свои отлом и вставляйте в марке под еобд 22.53
3 минуты назад, Алексей Вятка сказал:
Вставлять только LICENSE или ещё ADAP?
1 час назад, eek163 сказал:
- У Вас , походу, за 4 года и времени-то почитать тут что-то небыло....   :(
Если по делу нечего написать,лучше тогда вообще не писать.3 года всё работало,сменил телефон,заодно решил обновить марки,отсюда и спрашиваю
2 минуты назад, eek163 сказал:
Меняйте 4 файла.
  • Последние посетители   2 пользователя онлайн
