11den11 351 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 Приехал Mercedes Benz W164 SRS с кучей проблем, одна из них SRS горящий на приборке. По словам клиента не каких действий не было, что могло вызвать следующие ошибки - 1.9015 The Coding For Component S68/1(Seat Belt Buckle And Seat Belt Warning Switch, Driver) Is Faulty. 2.90A5 Incorrect Sensor Model B48/1(Driver-side Frontal Acceleration Sensor) Installed Or Control Unit N2/7(Restraint Systems Control Unit) Is Incorrectly Configured 3.90B5 Incorrect Sensor Model B48/2(Passenger-side Frontal Acceleration Sensor) Installed Or Control Unit N2/7(Restraint Systems Control Unit) Is Incorrectly Configured 4.9053 The Component Or The Signal Line To The Component S68/12(Right Rear Seatbelt Buckle Switch) Has Open Circuit Or Resistance Too Large. 5.90C5 Incorrect Sensor Model B48/7(Driver Door Pressure Sensor) Installed Or Control Unit N2/7(Restraint Systems Control Unit) Is Incorrectly Configured 6.92B0 The Resistance Value In The Ignition Circuit Containing Component R12/11(Left 2nd Row Sidebag Squib) Is Too High. 7.92C0 The Resistance Value In The Ignition Circuit Containing Component R12/12(Right 2nd Row Sidebag Squib) Is Too High. 8.90A8 The Coding For Component B48/1(Driver-side Frontal Acceleration Sensor) Is Faulty. 9.90B8 The Coding For Component B48/2(Passenger-side Frontal Acceleration Sensor) Is Faulty. 10.90D5 Incorrect Sensor Model B48/8(Front Passenger Door Pressure Sensor) Installed Or Control Unit N2/7(Restraint Systems Control Unit) Is Incorrectly Configured 11.90C8 The Coding For Component B48/7(Driver Door Pressure Sensor) Is Faulty. 12.90D8 The Coding For Component B48/8(Front Passenger Door Pressure Sensor) Is Faulty. 13.91D3 The Component Or The Signal Line To The Component B48(Front Passenger Seat Occupied And Child Seat Recognition) Has Open Circuit. 14.9025 The Coding For Component S68/2(Front Passenger Seat Belt Buckle And Seat Belt Warning Switch) Is Faulty. ............................... При этом меняли подрулевой шлейф ... два раза, так как была ошибка по датчику угла руля.... На вопрос - причем тут шлейф и датчик угла руля.... внятного ответа не получил. На быструю руку разобрал руль с подрулевым, так как датчик был сдвинут на один оборот и думал по быстрому переставить - фиксирующее кольцо крышки датчика не зафиксировано, скользящий штифт обломан.... На повторный вопрос что же меняли, ответ был кругляшку под рулем с хвостиком из проводов.... Ну ладно..., ну и..... записал его на другой день. Вопрос - что случилось с эбу SRS - помирает, или шаловливые ручки? Сколько игрался по работе с кодингами на MB, не помню такого итога..... Ссылка на комментарий Поделиться на другие сайты Поделиться
AutoNewLife 118 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 Так а какие ошибки активные ? 32 минуты назад, 11den11 сказал: На повторный вопрос что же меняли, ответ был кругляшку под рулем с хвостиком из проводов.... Вернуть все взад родное и смотреть что будет по ошибкам. Думаю там шаловливые ручки напортачили знатно Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 7 октября, 2025 Автор Поделиться Опубликовано 7 октября, 2025 26 минут назад, AutoNewLife сказал: Думаю там шаловливые ручки напортачили знатно Вот и у меня такие подозрения.... Но ошибки и по датчикам...! Как то я не помню возможность их кодировать. ... а может вода? Да, нужно будет Стар-ухой пройтись, но есть большие подозрения, что по каждому пункту будет - проверить провода и замена. Ссылка на комментарий Поделиться на другие сайты Поделиться
AutoNewLife 118 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 12 минут назад, 11den11 сказал: Вот и у меня такие подозрения.... Но ошибки и по датчикам...! Как то я не помню возможность их кодировать. ... а может вода? А смысл кодировать, если не известна причина возникновения ошибок? Там же не блок srs меняли. Нужно трясти клиента, пусть рассказывает всю правду. Не поверю что из-за датчика угла полезли в подрулевой и поменяли «кругляшку с проводами». Потом стереть все ошибки, посмотреть что активное останется. В параметрах лайфдаты посмотреть сопротивления по всем датчикам. 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
ohoo 1 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 Было похожое у меня перетерлись провода внизу под сиденьем 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 7 октября, 2025 Автор Поделиться Опубликовано 7 октября, 2025 2 минуты назад, AutoNewLife сказал: В параметрах лайфдаты посмотреть сопротивления по всем датчикам. ))))) Какие сопротивления могут быть у датчиков удара в дверях....?! Или у датчиков акселя? В том то и прикол! 6 минут назад, ohoo сказал: Было похожое у меня перетерлись провода внизу под сиденьем Как то все симметрично по сторонам... Ссылка на комментарий Поделиться на другие сайты Поделиться
Shuric 9 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 Клиент сам наверное не знает что меняли в этой машине, скорее всего блок SRS вообще не родной. 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 7 октября, 2025 Автор Поделиться Опубликовано 7 октября, 2025 2 минуты назад, Shuric сказал: Клиент сам наверное не знает что меняли в этой машине, скорее всего блок SRS вообще не родной. Как бы сей вердикт не сходится со словами хозяина. По его словам все заменяемые узлы он сам искал и передавал мастеру, а блока SRS точно в списках не было. Как то не вижу смысла говорить неправду...., да и блок заменить не пятиминутное дело. Кстати... хозя с траблой по SRS даже к дилеру ездили. Ответ был - не чем помочь не могут. Похоже блок SRS не родной.... И это офы так сказали!))))) Ссылка на комментарий Поделиться на другие сайты Поделиться
AutoNewLife 118 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 48 минут назад, 11den11 сказал: датчиков удара в дверях. А блин) я на ошибки даже не смотрел))) srs сразу в голове про подушки мысли) хотя сам же написал датчики)) пора спать🥱 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
RAZOR85 555 Опубликовано 7 октября, 2025 Поделиться Опубликовано 7 октября, 2025 Если есть стар в чем проблема по кодировкам пройтись? Возможно дохлый акум потянул эти траблы. 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 8 октября, 2025 Автор Поделиться Опубликовано 8 октября, 2025 6 часов назад, RAZOR85 сказал: Если есть стар в чем проблема по кодировкам пройтись? Старом по кодировкам пройтись...... Их там одна..., две..., три....? ))) Стар, конечно, есть... Пробежался быстро лаунчем (онлайн) - вообще не заметил не одного пункта влияющего на работу датчиков. Ну и хер... В понедельник приедет и буду копать. Хотелось погадать на кофейной гуще, но вы не лучшего уровня гадалки чем я сам....)))) Что только радует. Ссылка на комментарий Поделиться на другие сайты Поделиться
Avtosantehnik 117 Опубликовано 8 октября, 2025 Поделиться Опубликовано 8 октября, 2025 Одна или две кодировки думают юзеры мерсов когда покупают thinkdiag . Предполагают трахать свой мерс вдоль и поперек кодировками и считают что их яйца сразу в сейф попали. . Считают это же просто ,к примеру, отключить датчик оккупанта . За что деньги платить? Тут может думали подуху какую нибудь отключат . Ну и имеют трах на последующую жизнь. Был такой лет 7 назад . Приезжал стар купить после саморучной кодировки thinkdiag. Там пункт в кодировках вроде есть(на сколько помню) всё по дефалту или по выбору страны . Снес все. Думал я подключусь старухой и за 5 минут все сделаю и он у меня ее купит . Не получилось за 5 минут , ну и не купил . извините за флуд , как мой пример. Может и тут так поиграли кнопками . Сейчас только долгим путем получится. Malina и 11den11 1 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 8 октября, 2025 Автор Поделиться Опубликовано 8 октября, 2025 2 часа назад, Avtosantehnik сказал: Там пункт в кодировках вроде есть(на сколько помню) всё по дефалту или по выбору страны . На 164-ом все плохо с кодировками. Нет даже онлайн кодировки. 2 часа назад, Avtosantehnik сказал: Одна или две кодировки ))))) Ссылка на комментарий Поделиться на другие сайты Поделиться
Vasilitallin 111 Опубликовано 8 октября, 2025 Поделиться Опубликовано 8 октября, 2025 1 час назад, 11den11 сказал: На 164-ом все плохо с кодировками. Нет даже онлайн кодировки. Если Ксентри Лайт то кодировки онлайн для DAS в Спецпроцессах, в Пасстру DAS вообще кастрированый. 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 8 октября, 2025 Автор Поделиться Опубликовано 8 октября, 2025 10 минут назад, Vasilitallin сказал: Если Ксентри Лайт то кодировки онлайн для DAS в Спецпроцессах, в Пасстру DAS вообще кастрированый. ))) Я о кодировках в лаунч-е. Там больше комплектация чем кодировка. Старуха у меня не кастрированная.... Еще не подкидывал. У тебя было такое, чтоб из за кодировок слетали датчики удара или акселя? Я не припоминаю такого. Да и как то помниться мне, что если кодировка не соответствует данному транспортному средству, то ошибка так и звучит. Ссылка на комментарий Поделиться на другие сайты Поделиться
11den11 351 Опубликовано 13 октября, 2025 Автор Поделиться Опубликовано 13 октября, 2025 И вправду кодинг может привести к таким ошибкам. Пришлось даже release делать блоку, чтоб в чувства его привести. Закодировал, инициализировал и потом уже убрал все лишнее. Поспешил я с темой, но пусть будет тут. Может кто-то еще как и я испугается этих ошибок. Спасибо всем участникам сей пустой темы. RAZOR85 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
