Orange 5 китай
В 14.10.2023 в 08:02, guix сказал:
Also I read about contacting someone (@romario339 ?) who, if I understand correctly, made modifications to Orange5 software to get all licenses activated with 5C68, is this correct ?
@romario339 has a very good collection of calculators that he is constantly improving.  + In addition, he has two private chats in Telegram.  One of which is dedicated to technical support for the programmer and its calculators.  And the second one is on general issues of auto electrics, chiptuning and everything connected with it.  Where guys share experiences with each other and help each other.  But unfortunately @romario339 is not a god and cannot open new licenses.  So I'll say it again.  In your case, you should think about purchasing the clone version with serial number A021.  It has what you need.
4 часа назад, makskz сказал:
Всем салам, можете дать ссылку у какого продавца лучше заказать на алике
Этот вопрос для того чтобы пото м в случаи чего можно было кого обвинить, мол какого-то хренового продавца посоветовали? Есть рейтинг магазина, количество продаж и отзывы - удачи!
В 13.10.2023 в 21:55, Korsekanec сказал:
Тут еще большой вопрос какой из серийников круче, И смысл переплачивать.
Поддерживаю
for @guix and ALL
Так как пишу всем, поэтому на двух языках.
Orange-5 has several modes of finding SS codes. Some of them have passed since the time of Omega-MTRK. The latest version of the software for Omega-MTRK 1.35. M08V is made only for Orange-5. Try to install an old version of the program (for example, 1.35), perhaps the search button will be active in it if you change the MODE parameter. So the 68HC908AB32 chip was announced in both OMEGA-MTRK and Orange-5 with the M08V license. However, the MODE parameter was different. In Omega-MTRK, the MODE parameter has a decimal form, and in the case of M08V, a hexadecimal WORD. Apparently, the developers will improve the search mode and check how effective the new mode is on old chips. If the effect is positive, then the old chips are switched in the configuration file to use the new mode.
То же самое для русскоязычной аудитории форума
Оранж-5 имеет несколько режимов нахождения SS-кодов. Часть из них перешла со времен Omega-МТРК. Последняя версия софта для Омега-МТРК  1,35. M08V сделан только для Оранж-5. Попробуйте поставить старую версию программы (например 1,35) возможно в ней кнопка поиск будет активна, если изменить параметр МОДЕ. Так микросхема 68HC908AB32 была заявлена и в OMEGA-MTRK и в Оранж-5 с лицензией М08V. Однако параметр MODE был разный. В Омега-МТРК параметр MODE имеет десятичный вид, а в случае с М08V шестнадцатеричный WORD. Видимо разработчики усовершенствуют режим поиска и проверяют насколько новый режим эффективен на старых микросхемах. Если эффект положительный, то в конфигурационном файле переключают старые микросхемы на использование нового режима.
4 часа назад, Leks сказал:
Горе от ума....  Кто там чего перключет? :)
Разработчиками данного прибора, верней на сегодня те кому в наследство досталось все что было сделано до получения наследства, пусть им будет стыдно..., сидят на остатках этого наследства, и пытаются хоть как то манетизировать эти остатки. Еще и руки выкручавают своим клиентам и тем кто предлагает им помощь в поддержке.
То о чем вы тут пытаетесь догадаться, лежит в самом калькуляторе (он так написан еще в первых версиях прибора и перетекает в неизменном виде во все последующие) и активация этой опции была задумана для монетизации продукта.
Данный прибор еще жив благодаря немногим энтузиастам оценившим потенциал прибора и хоть как то еще его поддерживают программно.
Те же кому он достался в наследство, реального прогресса сделать не могут или просто не желают, считая что и так обладают "Золотым тельцом", за которым ухаживать не хотят, а на бойне дадут денег только за хвост и копыта.
В 22.10.2023 в 19:46, Korsekanec сказал:
Пусть земля будет пухом, Alex+. Этот человек внёс огромный вклад в развитие всей отрасли.
Сейчас оригинальный проект держится на скриптах Первомайска в основном...
Хотя огромный потенциал, железа прибора хватает и на обход SEC битов V850, и на написание других скриптов под свои нужды ;)
Ну не буду голословным и не буду переходить на личности, ибо с авторами этого проекта не знаком. Вот о чём я говорил, привожу конфиги из Omega-MTRK и Orange-5:
; Mtrk cfg file
CHIP=MC68HC908AB32,512,08az32.hpx
AREA=EEPROM,512(16/0),0800H
AREA=FLASH,32256(64),8000H,w
AREA=VECTORS,64(8),0FFC0H,w
BOOTFILE=08az32.boo
FREQ=4000
BAUD=7800
LOADER=08
IMAGE=08azq64
MODE=2
; Orange5 motorola cfg file v.1.36.0
CHIP=MC68HC908AB32,512,moto\908ab32.hpx
AREA=EEDIV,2(2/0),0FE10H
AREA=FLASHE,16(16),0FFC0H
AREA=VECTORS,48(8),0FFD0H
AREA=MONROM,307(16),0FE20H,w
FREQ=4000
BAUD=7800
IMAGE=08azq64
MODE=0x5049
Поясните о каком калькуляторе идёт речь, я непонял. Вы считаете что неизвестные SS-коды Orange-5 расчитывает с помощью каких-то математических преобразований?!
1 час назад, Leks сказал:
; Mtrk cfg file
BOOTFILE=08az32.boo
FREQ=4000
BAUD=7800
LOADER=08
IMAGE=08azq64
MODE=2
FREQ=4000
BAUD=7800
IMAGE=08azq64
MODE=0x5049
908 процы подвержены уязвимости, по токопотреблению можно отслеживать результативность перебора SS и тем самым проводить не полный брут, а частичный.
В 11.07.2023 в 15:06, Ramzes13 сказал:
Хорошие новости!
Комплект обновлений orange5 для orange5 1,34 1,35 1,36 1,37 обновление до версии 1,38 полная лицензия
Так заявляют.Алик
кто то ставил этот кит? Какой серийник?
Судя по всему будет 5C38
Как по мне - самый топовый отлом на данное время.
Ещё до кучи Романа сборку прикупить и вообще огонь
Серийник 5C38 ставил на свой 1.36 после того как тот умер перестал определяться компом. Кит писал что работает только на Вин 7.
2 минуты назад, Cops1 сказал:
У меня 5C38 отлично работает на Windovs11
7 минут назад, Cops1 сказал:
перепаиваем проц из комплекта,еще микруху и ставим панель из кита(она тоже с процом по виду)?
16 минут назад, Alex366 сказал:
Всё верно.
Не согласен, достался он нормальным профессионалам. Скорее всего, из-за китайцев этот проэкт стал второстепенным и основные силы тратятся на другое.
2 часа назад, Cops1 сказал:
Если не спеша 30 Мин работы.
открыл свой,у меня плата другая,придётся на проводах вешать похоже
20231026_133648.thumb.jpg.79781bf5166baafb1b96c81e7fa0b235.jpg20231026_132415.thumb.jpg.2414342148e288f8e3250319654c34c2.jpg
2 минуты назад, Alex366 сказал:
Первый раз такое слышу. Что за прибор у вас? Фото платы.
Какой серийник у вас был на этом железе?
Так может подрезать новую платку. Что там на ней с обратной стороны, где упирается в разъем? Так может подрезать новую платку. Что там на ней с обратной стороны, где упирается в разъем?
подрезать не проблема,есть на новой плате 8ми пиновый раъем,на мат.плату,я так понимаю проводами.куда и как не понятно
красным отметил переход,который не понятно куда паять,к 8 ногой микросхеме похоже,но нужен распин.В чайну написал
фото прибора.Серийный уже не 20231026_132009.thumb.jpg.b5cccfc604122ffcb9761af6ffeff341.jpg20231026_132415(1).thumb.jpg.0ef91baef45fae1243cda8f152cf5cf0.jpgувижу,плата оторвана
Я так полагаю, что проц который распаян на плате эмулирует работу 45BD и эти 8 маленьких точек соединяются с падами на плате где сейчас стоит 45bd вместо микры
25 минут назад, andron_h сказал:
её сдувать получается? 45BD это микра,к которой припаяны провода были?
Доброго дня. Прошу пояснить или хоть намекнуть(sn 5c38, soft 1.38) - почему кнопки не активны? Или это просто калькулятор? И читаются эти неки оранжем. Заранее спасибо.
22 часа назад, boston666 сказал:
Прочитав всю ветку - вроде разобрался, кальк криптованный. Не под мой серийник.
В 26.10.2023 в 09:43, MotoEgor сказал:
На 10 полет нормальный ;)
Коллеги, подскажите как связаться Romario339 по поводу кальков? В личку написал сообщение, но ответа нет...
  • Последние посетители   3 пользователя онлайн
