minewu13 0 Опубликовано 7 ноября Поделиться Опубликовано 7 ноября Summary of Power‑Steering Issue – VW Passat 2012 Initial symptoms – The power steering worked normally, but the horn and steering‑wheel buttons were dead and there was a faint squealing noise when turning the wheel. This pointed to a defective clockspring (spiral ribbon). Repair attempt – To access the clockspring, the mechanic disconnected the steering‑angle sensor (G85) and the spiral ribbon and moved the car while these parts were unplugged. After that, the steering assist stopped working entirely. Diagnostic scan showed two fault codes: 02546 – Steering limit stop: no/incorrect basic setting – meaning the control unit no longer knows the end‑stop positions. 03375 – Steering motor: mechanical failure – a safety lockout that is set when the car is moved with the steering‑angle sensor disconnected. Current status – The mechanic has repaired or coded the spiral ribbon so that the horn and buttons now work and there is no “spiral error,” but the power steering is still inactive and both codes remain stored. Help/fixes/reccommendations?? its very urgent Ссылка на комментарий Поделиться на другие сайты Поделиться
Dmitriy79 354 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 2 часа назад, minewu13 сказал: Summary of Power‑Steering Issue – VW Passat 2012 Initial symptoms – The power steering worked normally, but the horn and steering‑wheel buttons were dead and there was a faint squealing noise when turning the wheel. This pointed to a defective clockspring (spiral ribbon). Repair attempt – To access the clockspring, the mechanic disconnected the steering‑angle sensor (G85) and the spiral ribbon and moved the car while these parts were unplugged. After that, the steering assist stopped working entirely. Diagnostic scan showed two fault codes: 02546 – Steering limit stop: no/incorrect basic setting – meaning the control unit no longer knows the end‑stop positions. 03375 – Steering motor: mechanical failure – a safety lockout that is set when the car is moved with the steering‑angle sensor disconnected. Current status – The mechanic has repaired or coded the spiral ribbon so that the horn and buttons now work and there is no “spiral error,” but the power steering is still inactive and both codes remain stored. Help/fixes/reccommendations?? its very urgent neispravnost' rulevoy reyki , proshit' odis Ссылка на комментарий Поделиться на другие сайты Поделиться
minewu13 0 Опубликовано 8 ноября Автор Поделиться Опубликовано 8 ноября 1 hour ago, Dmitriy79 said: steering rack malfunction, ask for odis Ok, What exactly has to be done in odis? can you guide Ссылка на комментарий Поделиться на другие сайты Поделиться
OnlyVags 53 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 5 часов назад, minewu13 сказал: Хорошо, что именно нужно сделать в Odis? Можете подсказать? Есть Odis Engineering? 5 часов назад, minewu13 сказал: Ссылка на комментарий Поделиться на другие сайты Поделиться
arturito 22 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября VCDS says: 'Steering motor mechanical failure' And I think It's true. Thirst of all You must change Steering Power Unit and next - to do adaptations with VCDS. I did it once with VCDS. VCDS it's enough. Somebody was writing - 'only parametrisation with ODIS online'. It's not true. One guy from Germany was trying to reflash via ODIS online (I did pay to him) but it didn't work. Then I changed Steering and did myself with VCDS. (I did have same error in 44) To '11den11': Thank You for a beer, but It's not real, so '+' much better 11den11 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
SSergey 42 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 13 часов назад, minewu13 сказал: Summary of Power‑Steering Issue – VW Passat 2012 Initial symptoms – The power steering worked normally, but the horn and steering‑wheel buttons were dead and there was a faint squealing noise when turning the wheel. This pointed to a defective clockspring (spiral ribbon). Repair attempt – To access the clockspring, the mechanic disconnected the steering‑angle sensor (G85) and the spiral ribbon and moved the car while these parts were unplugged. After that, the steering assist stopped working entirely. Diagnostic scan showed two fault codes: 02546 – Steering limit stop: no/incorrect basic setting – meaning the control unit no longer knows the end‑stop positions. 03375 – Steering motor: mechanical failure – a safety lockout that is set when the car is moved with the steering‑angle sensor disconnected. Current status – The mechanic has repaired or coded the spiral ribbon so that the horn and buttons now work and there is no “spiral error,” but the power steering is still inactive and both codes remain stored. Help/fixes/reccommendations?? its very urgent Are the readings from sensor G85 displayed in diagnostics? Ссылка на комментарий Поделиться на другие сайты Поделиться
minewu13 0 Опубликовано 8 ноября Автор Поделиться Опубликовано 8 ноября 5 hours ago, OnlyVags said: Есть Odis Engineering? Yes it is. online access can be paid if needed, let me know what exactly has to be done?. 48 minutes ago, SSergey said: Are the readings from sensor G85 displayed in diagnostics? As far as I know no, but I can double check tonight and let You know. another electrician did it, and colleague askede for help/opinion. many thanks anyway. If You know more lmk. 1 hour ago, arturito said: VCDS says: 'Steering motor mechanical failure' And I think It's true. Thirst of all You must change Steering Power Unit and next - to do adaptations with VCDS. I did it once with VCDS. VCDS it's enough. Somebody was writing - 'only parametrisation with ODIS online'. It's not true. One guy from Germany was trying to reflash via ODIS online (I did pay to him) but it didn't work. Then I changed Steering and did myself with VCDS. (I did have same error in 44) To '11den11': Thank You for a beer, but It's not real, so '+' much better Before unpluging spiral and sensor steering was working fine, then they moved car, somehow this “electrician” fixed spiral error, but then this appeared. also if I forgot to mention, when spiral was “not working” and they unplugged sensor and moved car, car was unable to unlock with main key, with reserve key it is possible, while locking was working. Ссылка на комментарий Поделиться на другие сайты Поделиться
arturito 22 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 3 hours ago, minewu13 said: Before unpluging spiral and sensor steering was working fine, then they moved car, somehow this “electrician” fixed spiral error, but then this appeared. also if I forgot to mention, when spiral was “not working” and they unplugged sensor and moved car, car was unable to unlock with main key, with reserve key it is possible, while locking was working. You asking for help, but don't trust. As I understood G85 is working fine, but DTC about mechanical failure and incorect basic settings still exists. Someone somehow somewhere moved a car/ unplaged sensor... You don't know real story of car and relying what someone say to You... And I say - it's better rely to VCDS. I did have exacly same errors in 44 block (in Audi A4, 2013y). Someone was flashing 44 before me a couple times, I also was flashing with VCP, one guy from Mhauto (from Germany) said only ODIS online parametrisation will help... Didn't work. Finally did help a Steering Power Unit replacement with whole mechanical part and VCDS Ссылка на комментарий Поделиться на другие сайты Поделиться
OnlyVags 53 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 4 часа назад, minewu13 сказал: Yes it is. Могу вам помочь, нужен Odis E. и доступ к вашему компьютеру через Anydesk. Если интересует пишите в приват) Ссылка на комментарий Поделиться на другие сайты Поделиться
arturito 22 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 5 hours ago, minewu13 said: Before unpluging spiral and sensor steering was working fine, then they moved car, somehow this “electrician” fixed spiral error, but then this appeared. also if I forgot to mention, when spiral was “not working” and they unplugged sensor and moved car, car was unable to unlock with main key, with reserve key it is possible, while locking was working. You asking for help, but don't trust. As I understood G85 is working fine, but DTC about mechanical failure and incorect basic settings still exists. Someone somehow somewhere moved a car/ unplaged sensor... You don't know real story of car and relying what someone say to You... And I say - it's better rely to VCDS. I did have exactly same errors in 44 block (in Audi A4, 2013y). Someone was flashing 44 before me a couple times, I also was flashing with VCP, one guy from Mhauto (from Germany) said only ODIS online parametrisation will help... Didn't work. Finally did help a Steering Power Unit replacement with whole mechanical part and VCDS One more advice: the steering wheel symbol in the Dash must be yellow (incorect settings, parametrisation etc). Only in this condition You can expect success and proceed to do something with VCDS or ODIS Ссылка на комментарий Поделиться на другие сайты Поделиться
Shapdiagnostics 47 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 19 часов назад, minewu13 сказал: 02546 – Steering limit stop: no/incorrect basic setting – meaning the control unit no longer knows the end‑stop positions. Set the basic setting 19 часов назад, minewu13 сказал: 03375 – Steering motor: mechanical failure Software incompatibility. The power steering J500 need to be flashed through ODIS Online. Ссылка на комментарий Поделиться на другие сайты Поделиться
arturito 22 Опубликовано 8 ноября Поделиться Опубликовано 8 ноября 10 minutes ago, Shapdiagnostics said: Software incompatibility. The power steering J500 need to be flashed through ODIS Online. Before disconnecting a steering angle sensor software was compatible. How did it come incompatible? (flat battery?) I don't think so. For flashing You don't need ODIS, VCP is enough Ссылка на комментарий Поделиться на другие сайты Поделиться
SSergey 42 Опубликовано 9 ноября Поделиться Опубликовано 9 ноября You need to ensure that the G85 sensor is assembled and installed correctly. Check the readings. If you see 0 degrees, the G85 sensor is ready for initialization, but it can't initialize due to different readings from the ABS wheel sensors. If we see a constant reading above 3000 degrees, the problem is in the G85 sensor. Error 000 can be cleared by flashing the rack to version 1002, then upgrading it to the latest version. These procedures do not require online access. Parameterization is also optional. Ссылка на комментарий Поделиться на другие сайты Поделиться
