Scanmatik 2 pro, установка Bluetooth модуля.
  • Ответов 200
  • Создана
  • Последний ответ
Топ авторов темы
#include "BluetoothSerial.h"
#include "driver/uart.h"
#define BAUD_RATE  115200 * 8
#define SIZE_BUFFER  256
#define SIZE_FIFO   SIZE_BUFFER * 8
#define SAVE_MODE
//#define DEBUG_MODE
//#define USE_PIN
#ifdef USE_PIN
const char* pin = "1234";
#endif
const String device_name = "SCANMATIK #A111788";
BluetoothSerial SerialBT;
uint8_t buffer[SIZE_BUFFER];
unsigned int available=0;
unsigned int availableBT=0;
size_t bytesRead=0;
size_t bytesWrite=0;
#ifdef SAVE_MODE
  uint32_t min_delay = 1;
  uint32_t max_delay = min_delay * 1024;
  uint32_t cur_delay = min_delay;
  uint32_t critical_size = SIZE_FIFO / 2;
#endif
#ifdef DEBUG_MODE
  #include <chrono>
  using namespace std::chrono;
  auto timePointSerial = high_resolution_clock::now();
  auto timePointBT = high_resolution_clock::now();
#endif
void setup() {
  Serial.setRxBufferSize(SIZE_FIFO);
  Serial.setTxBufferSize(SIZE_FIFO);
  Serial.begin(BAUD_RATE);
  memset(buffer, 0, sizeof(buffer));
  // setup UART from hardware (RTS/CTS)
  uart_set_pin(UART_NUM_0, 1, 3, 22, 19); // UART, TX, RX, RTS, CTS
  uart_set_hw_flow_ctrl(UART_NUM_0, UART_HW_FLOWCTRL_CTS_RTS, 64);
  uart_set_mode(UART_NUM_0, UART_MODE_UART);
  SerialBT.begin(device_name);
  #ifdef USE_PIN
    SerialBT.setPin(pin);
  #endif
  Serial.print("AT-AB -BypassMode-\n");
void loop() {
  available = Serial.available();
  if (available > 0) {
    bytesRead = Serial.readBytes(buffer, min(available, sizeof(buffer)));
    bytesWrite = SerialBT.write(buffer, bytesRead);
#ifdef SAVE_MODE
    if (cur_delay > min_delay) {
        cur_delay /= 2;
#endif
#ifdef DEBUG_MODE
    auto timeoutSerial = high_resolution_clock::now() - timePointSerial;
    Serial.printf("\n\rAvailable from Serial %u, cur_delay %u , timeout %u\n", available, cur_delay, duration_cast<microseconds>(timeoutSerial).count());
    Serial.printf("\n\rFrom Serial to BT Read = %u, Write = %u\n", bytesRead, bytesWrite);
#endif
  availableBT = SerialBT.available();
  if (availableBT > 0) {
    bytesRead = SerialBT.readBytes(buffer, min(availableBT, sizeof(buffer)));
    bytesWrite = Serial.write(buffer, bytesRead);
#ifdef SAVE_MODE
        cur_delay /= 2;
#endif
#ifdef DEBUG_MODE
    auto timeoutBT = high_resolution_clock::now() - timePointBT;
    Serial.printf("\n\rAvailable from BT %u, cur_delay %u, timeout %u\n", availableBT, cur_delay, duration_cast<microseconds>(timeoutBT).count());
    Serial.printf("\n\rFrom BT to Serial Read = %u, Write = %u\n", bytesRead, bytesWrite);
#endif
#ifdef SAVE_MODE
  if ((available < critical_size) && (availableBT < critical_size)) {
    delay(cur_delay);
  if ((available <= 0) && (availableBT <= 0)) {
    if (cur_delay < max_delay) {
      cur_delay *= 2;
#endif
для визуального контроля работы интерфейсов раскоментировать //#define DEBUG_MODE
Это для экспериментов до установки в сканматик. Устанавливать с включенным DEBUG лучше не надо
Это исходный код для Ардуины IDE. Проверял да, на ESP32. Для DEBUG режима надо соединить с какой USB-TTL платой способной работать на высоких скоростях. Годится дешевый программатор на CH341A. Далее запускаем терминал где можно отправлять файлы и выставить соответствующую скорость. Cгодится minicom на передачу  и Putty для приема. Не забываем и про блютуз. Для передачи файла на блютуз готового решения не нашел, пришлось свой скрипт на питоне сварганить. По поводу размера буфера. 128 должно было в теории хватать для устойчивой работы. Но при длительной передаче заметил что буфер FIFO постепенно заполняется под завязку что чревато потерей данных. При 256 такой проблемы не заметил. Увеличивать до 512 смысла не вижу. Будет страдать отзывчивость системы. Все-таки у нас один поток и все операции выполняются последовательно.
Прошивка энергосберегающая. Применяется динамическая задержка от 1 до 1024 миллисекунд в зависимости от загрузки системы. В результате потребление системы снижается до 45 - 55 ма в состоянии покоя. Переход от максимальной задержки к минимальной в пределах значения максимальной задержки. При загрузке буферов FIFO больше половины задержка не применяется.
максимальную задержку вполне можно увеличить до 2048 или даже 4096 но это надо проверять в работе на сканматике. я свою плату еще не подключал.
  • 1 месяц спустя...
Всем привет. Подумываю прикрутить блютуз, но чёт кругом голова, что выбрать?
Есть у меня кучка разных esp32 и скетчи тут лежат в открытом виде (прав качать нет), но привлекательным вижу вариант на hc-05 в силу энергопотребления, но архив скачать не могу - что с HC-05 надо сделать, чтобы завёлся?
Upd. Сам поискал информацию, заказал в итоге HC-06 (его должно тоже хватить).
Насколько я понял нужно просто его настроить АТ командами (скорость, имя, пин-код) и припаять gnd, 3.3v, rx и tx.
3 часа назад, Demacr сказал:
Немного не так с помощью ат команд в стандартной прошивке вы управление потоком не включите и подключать нужно ещё rts и cts для управления потоком (то есть не 4 провода а 6 ) посмотрите на примере esp32, есть ещё один нюанс, блютуз модуль (не программа) шлёт в МК (stm32f105) сообщение (типо я готов к передачи данных)без этого сообщения stm32 не будет работать с модулем (сообщение можно посмотреть в скетче к esp32) так что без прошивки ничего не получится
В 22.06.2025 в 00:29, Demacr сказал:
Что так волнует энергопотребления он запитывается от аккумулятора автомобиля
Всем здравствуйте. Решил установить на китайматик модуль esp32. Подключил его к машине по ОБД всё чётко, работает. Тут как-то решил по USB его подключить к компьютеру, и слышно на windows постоянные отвалы USB с периодичностью в секунду. Отпаял питание от esp32, всё заработало. Заметил, что микросхема adum5000 сильно греется, бывает даже пальцем не стерпеть. И греется даже без bluetooth модуля. Не подскажете почему может греться? Мерил напряжение на стабилизаторе вроде всё норм 3 3 Вольта имеется. На входе где-то 4,8 стабильно. Ну и честно сказать я не электронщик, в радиоинститут не поступал))). Раньше я не обращал внимания на нагрев, пока bluetooth ставить не ставил. Трансиверы меняны давно.
11 часов назад, Serj_Pro сказал:
Adum5000 по даташиту 100ма даже в оригинале греется пока питание берётся через юсб при подачи отдельного питания (обед разъём) нагреваться перестает в вашем случае скорее всего плата с золотистыми контактами и адум5000 поддельная  рассчитана на ещё меньший ток. Вам стоит или заменить adum5000 ( на что-то более мощное) либо совсем её убрать (поставить перемычки ) возможно ещё посмотреть номиналы резисторов в dc-dc преобразователе китаймата
В 01.07.2025 в 01:18, Serj_Pro сказал:
Чтобы не отвалилался USB в начале подключи питание от OBD разъема, потом в комп втыкай не будет отвалится
В 01.07.2025 в 11:11, deman-s сказал:
Подтверждаю. Да, плата с золотистыми контактами. У меня кстати есть ещё один китайматик(тот что в черном корпусе ) так вот на нем все чётко работает, ниче не греется и не отваливается. На нем и блютуз четко пашет, без нареканий.
Только что, Serj_Pro сказал:
У меня кстати есть ещё один китайматик(тот что в черном корпусе ) так вот на нем все чётко работает, ниче не греется(адум 5000 еле теплая) и не отваливается. На нем и блютуз четко пашет, без нареканий.  И adum5000 по внешнему виду и маркировке чётче выглядит
В 22.06.2025 в 11:55, deman-s сказал:
Да ещё и hc-06 сейчас выше 115 не поддерживают, как оказалось.
А вот про спец команду это вы очень вовремя мне написали - я в итоге взял esp32 и скетч писал сам (выше несколькими сообщениями не увидел 😵‍💫) и эту строку не добавлял (подумал, что кто-то из примера какого-нибудь перетянул) и в итоге 3 дня мучаюсь 😂
Только что, Demacr сказал:
Есть готовая прошивка для ESP
29 минут назад, Demacr сказал:
С чего вы взяли что hc-06 не поддерживает скорость выше 115 в программе ps tool можете выставить даже выше 921600  в прошивке с помощью ат команд выше не настроите а вот с помощью программы ps tool вполне возможно
48 минут назад, deman-s сказал:
Ааа. Ну в любом случае я так понимаю флоу контроль и команду инициализации только через программатор можно было внести. HC-06 уже вернул.
6 часов назад, Demacr сказал:
Все правильно прошивка сложнее и модулей поддельных тоже много
Вообщем ура, все заработало. Взял скетч, где прописан SAVE_MODE, но сам режим выключил.
Дополнительно в setup прописал esp_wifi_stop() и esp_wifi_deinit() и добавил светодиод статуса связи.
Подключил сканматик через usb тестер - во время автоопределения блока двигателя (сканмат никуда не подключен) потребление 170 мА (на весь сканмат). Считаю, что более чем достойно и можно не заморачиваться с доп. стабом.
Кстати, у 1117 по даташиту вообще-то 1.1А в максимуме.
10 часов назад, Demacr сказал:
Совершенно напрасно! Как мне представляется плата в основном будет выполнять дурную работу, увеличивая риск выхода из строя микросхемы питания. Любой кто запускал бесконечный цикл, знает как это грузит систему. Другое дело поиграться со значением переменной для максимальной задержки.
Делать это имеет смысл если раньше приписана инициализация и старт модуля.
  • 5 недель спустя...
Добрый день. Подскажите купил Есп32, прошил, запаял в см2про, комп видит блютуз и подключается, привязал к проге сканматик, блютуз определяется, но при подключении к авто-- нет связи. В чем может быть проблема?
Возможно прошивка не соответствует разпиновке. В сети гуляет 2 варианта разпиновки и прошивки.
  • Последние посетители   2 пользователя онлайн
