ngocan 3 Опубликовано 30 января, 2022 Поделиться Опубликовано 30 января, 2022 I have problem with fuel pump control (output control signal pin 9 of 58 pin connector) on SDI6 ECU was water damage and I clean all corrosion on PCB board Now car can't start because fuel pump not operate and no fuel pressure with code "P025A Fuel Pump Module Control Circuit/Open" If I emulator pulse to pin 9 (fuel pump control signal) of 58 pin connector, fuel pump operate and car start OK. My problem is the line from pin 9 go to driven IC (ATIC39-B4) on PCB board is disconnect so I can't find where it go to with VOM (I compared with Simos 8.3 hardware, fuel pump control line go to ATIC39-B4) If you have SDI6 ECU please help me trace the line from Pin 9 (58 pin connector) where it go to ? (ATIC39-B4 or other IC ) Thanks you very much ! Ссылка на комментарий Поделиться на другие сайты Поделиться
regs40 89 Опубликовано 30 января, 2022 Поделиться Опубликовано 30 января, 2022 Hey! You need to look for a connection between this pin and the anode terminal of the diode near atik 39. And from its cathode, find a connection with the atik output. This is the scheme for connecting an atik with some loads. Good luck! shatei 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
ngocan 3 Опубликовано 30 января, 2022 Автор Поделиться Опубликовано 30 января, 2022 11 minutes ago, regs40 said: Hey! You need to look for a connection between this pin and the anode terminal of the diode near atik 39. And from its cathode, find a connection with the atik output. This is the scheme for connecting an atik with some loads. Good luck! Thanks for your help ! I was try with all diode around ATIC39 but no luck . The line of circuit board was burn before them. Ссылка на комментарий Поделиться на другие сайты Поделиться
k0tik0v 92 Опубликовано 30 января, 2022 Поделиться Опубликовано 30 января, 2022 Буржуи в своем репертуаре - попробуйте написать на забугорном форуме по русски, Вас или заклюют тут же, или в лучшем случае, порсто проигнорируют, сами же приходя на русскоязычный форум , считают вполне себе нормальным писать по английски в любой теме shatei 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
shatei 52 Опубликовано 30 января, 2022 Поделиться Опубликовано 30 января, 2022 Дам ТС подсказку на примере другого блока, если в теме ,то разберется Спойлер Ссылка на комментарий Поделиться на другие сайты Поделиться
ngocan 3 Опубликовано 30 января, 2022 Автор Поделиться Опубликовано 30 января, 2022 7 hours ago, k0tik0v said: Буржуи в своем репертуаре - попробуйте написать на забугорном форуме по русски, Вас или заклюют тут же, или в лучшем случае, порсто проигнорируют, сами же приходя на русскоязычный форум , считают вполне себе нормальным писать по английски в любой теме Спасибо, что напомнили мне, я буду использовать Google для перевода на русский язык. Надеюсь, все прочитают и поймут! 7 hours ago, shatei said: I’ll give the TS a hint on the example of another block, if it’s in the subject, then it’ll figure it out hide contents Спасибо за вашу помощь. Я пробовал ваше решение, но безуспешно. На вашем фото аппаратно управляет ВКЛ-ВЫКЛ катушкой реле бензонасоса. На Siemens SDI6 контакт 9 является выходом генератора импульсов (форма волны) для управления сигналом от ЭБУ топливного насоса. Ссылка на комментарий Поделиться на другие сайты Поделиться
alex676kz 16 Опубликовано 30 января, 2022 Поделиться Опубликовано 30 января, 2022 Если была вода то под микроскоп и межслойные переходы смотреть надо. И где больше была вода то поднимать чипы под ними тоже быстро сгнивает. Удачи. Ссылка на комментарий Поделиться на другие сайты Поделиться
ngocan 3 Опубликовано 31 января, 2022 Автор Поделиться Опубликовано 31 января, 2022 8 hours ago, alex676kz said: Если была вода то под микроскоп и межслойные переходы смотреть надо. И где больше была вода то поднимать чипы под ними тоже быстро сгнивает. Удачи. Спасибо за совет. но сначала я должен знать, какая микросхема управляет этим выводом, потому что есть три микросхемы ATIC39. Я не хочу поднимать их все, чтобы найти линию трещины на печатной плате. Ссылка на комментарий Поделиться на другие сайты Поделиться
alex676kz 16 Опубликовано 31 января, 2022 Поделиться Опубликовано 31 января, 2022 13 часов назад, ngocan сказал: Спасибо за совет. но сначала я должен знать, какая микросхема управляет этим выводом, потому что есть три микросхемы ATIC39. Я не хочу поднимать их все, чтобы найти линию трещины на печатной плате. Так этого не кто не знает или не помнит. Сократить время только методом исключения можно. Ссылка на комментарий Поделиться на другие сайты Поделиться
54diagnostika 357 Опубликовано 31 января, 2022 Поделиться Опубликовано 31 января, 2022 Ну нет у человека мультиметра с прозвонкой! обясните ему наконец как лампочкой на 220вольт найти проблему… Ссылка на комментарий Поделиться на другие сайты Поделиться
alex676kz 16 Опубликовано 31 января, 2022 Поделиться Опубликовано 31 января, 2022 1 минуту назад, 54diagnostika сказал: Ну нет у человека мультиметра с прозвонкой! обясните ему наконец как лампочкой на 220вольт найти проблему… Нет мультик есть ))) Человек хочет service manual на этот ЭБУ или чтоб точно ткнули что и куда идёт )) Ссылка на комментарий Поделиться на другие сайты Поделиться
ngocan 3 Опубликовано 1 февраля, 2022 Автор Поделиться Опубликовано 1 февраля, 2022 8 hours ago, 54diagnostika said: Ну нет у человека мультиметра с прозвонкой! обясните ему наконец как лампочкой на 220вольт найти проблему… У меня есть мультиметр с циферблатом (VOM), но моя проблема в том, что медная линия в слое печатной платы была отсоединена, поэтому я не могу проверить, куда она идет с VOM. Мне нужно, чтобы у кого-нибудь была хорошая печатная плата, помогите мне проверить с помощью VOM. 9 hours ago, alex676kz said: Так этого не кто не знает или не помнит. Сократить время только методом исключения можно. Это будет последнее решение, если никто не сможет мне помочь! Ссылка на комментарий Поделиться на другие сайты Поделиться
Lamaster 12 Опубликовано 12 февраля, 2022 Поделиться Опубликовано 12 февраля, 2022 Уж слишком ты грамотно пишешь на русском, для англоязычного. И таких на форуме валом. То с крайнего севера, где только олени ездят, задают вопрос про камазы, то африканцы, то австралийцы... Заполняйте профиль по факту. Не чего скрывать свое место проживания. Ссылка на комментарий Поделиться на другие сайты Поделиться
ngocan 3 Опубликовано 16 февраля, 2022 Автор Поделиться Опубликовано 16 февраля, 2022 Моя проблема была решена. Я хотел бы поделиться результатом и надеюсь, что это поможет кому-то столкнуться с этим. Я нашел контакт 29 ATIC39. Это управляющий сигнал для ЭБУ топливного насоса. Спасибо вам всем, брат, помог мне. On 13.02.2022 at 06:57, Lamaster said: Уж слишком ты грамотно пишешь на русском, для англоязычного. И таких на форуме валом. То с крайнего севера, где только олени ездят, задают вопрос про камазы, то африканцы, то австралийцы... Заполняйте профиль по факту. Не чего скрывать свое место проживания. Вся информация обо мне является фактом. Я приехал из Вьетнама. Я вьетнамец. regs40, Alex366 и dyrokol 3 Ссылка на комментарий Поделиться на другие сайты Поделиться
Lamaster 12 Опубликовано 19 февраля, 2022 Поделиться Опубликовано 19 февраля, 2022 Прошу прощения. Ссылка на комментарий Поделиться на другие сайты Поделиться
