Renault Electronic 2 411 Опубликовано 20 ноября, 2019 Поделиться Опубликовано 20 ноября, 2019 АКТУАЛЬНЫЕ ЦЕНЫ УЗНАВАЙТЕ В ЛИЧНЫХ СООБЩНИЯХ!!! NEC KEY + ONLINE Спойлер NEC v.10.65 is a basic, start package for Mercedes-Benz key programming. Although it’s just a first step in Mercedes-Benz programming it has huge possibilities and allows to not only read/ erase/ program keys in cars but also do basic diagnostics on keys (like with the use of MB Key Expert). With the use of NEC PCB (included in the set) one can easily read/erase/write NEC processors used in Mercedes keys. If you work with older generation of keys, you can use MBE EEPROM programmer, to read/rease/write information in Motorola processors. Коллеги, на данный момент, мы договорились о скидке на девайсы от MBE Engineering. На сегодняшний день, вы можете приобрести их продукцию со скидкой (через форум carmasters.org). ЦЕНА 210 ЕВРО ( для всех участников форума ) 190 ЕВРО ( для форумчан с репутацией +50 ) MAXI - BGA + 204/207 Спойлер MB prog MAXI is an evolution with a special add-on of BGA/204/207 software, set of software and hardware that covers entire set of Mercedes keys programming. When we were designing MAXI kit set, we had in mind that when it comes to key programming, this set should cover not only new IR keys, but also transponder keys and first generation of IR keys (flip keys). MAXI kit contains not only key programming tools but also tools that allow erasing of the modules in Mercedes-Benz cars (including ECU’s and gearbox) and also testing on the bench. MAXI kit contains also emulators and one key, ready to be used. BGA At least one key MANUAL BGA All keys lost MANUAL BGA At least one key VIDEOMANUAL BGA All keys lost VIDEOMANUAL What is the most important add-on is a function that allows in an easy way, to read password and program keys in vehicles with BGA keys: Add key (at least one existing key), list below covers only BGA equipped vehicles W164 2009 + W166, W197 W212 W218 W246 W169 W209 W211 W172 W204 C207 W216 W221 W639 2009+ All key lost, list below covers only BGA equipped vehicles W204 C207 W166 W197 W212 W218 W246 All calculations for BGA keys are done on-line and internet connection is required; software works in pay-per-use way. It comes with 20 credits (20 password calculated). Set contains: HARDWARE: -MB Keyprog 2 EVO main adapter -IR Key Tools W204/W207 -MB Magic Eraser + connection cable -204/207 adapter -204/207 click 'n go -PCB adapter: DB9 main + 3 NEC PCB -USB cable -USB security dongle (may be included in MBKeyprog 2 Evo device, not seperately) -DATA flash memory card -NEC IC Socket -EEPROM Programmer -EIS/ESL Testing tool -MB Testing key -MBprog HC05/08/12 programmer -2 adapters: MC68HC05x32, MC68HC05E6 -MB 38 pin cable -ESL Emulator slim type -MB main OBD cable + OBD female power -BE key 433 or 315 Mhz -ESL NEC chip emulator -MB Coil detector -28 PIN clip -MB Keymaker SOFTWARE: -BGA software -204/207 software -Sonderhash account -NEC Prog v. 12 -IR Tools basic software -IR Tools EZS password reader -ESL/ELV Evo Prog -Eeprom programmer -Multiprog -ML Keymaker -MB Keyprog-2 v. 1.5 -MB Keyprog Lite v. 2.11 -MB Key Restorer -ECU CR1/2 Reader -IR Tools Advanced - Key Emulation -Online key calculation access -MB Magic Eraser software -MB PCF Keymaker (for ML device) -MB Truck Keymaker (for ML device) -Dodge Sprinter (for ML device) -20 credits Attention: if you have existing MBE Engineering set, you can contact us to update your set to work with BGA/204/207 vehicles. Contact us directly. ЦЕНА: 2200 ЕВРО ( для всех участников форума ) 2100 ЕВРО ( для форумчан с репутацией +50 ) MAGIC Bench Connect EVO Спойлер Magic Bench Connect EVO is a device that allows you to connect it to modules on bench in order to test their functionality. Other items in the package can can be connected to this device to extend the functionality. With MDPprog functions you can read/write EEPROM and Flash datas. Diagnostic functions: • Test modules on bench • Basic vehicle diagnostic tests • Read/Reset ECU/W204 ELV/Gearbox/ISM/DSM • Testing EIS and ELV on bench (Optional) • Test dashboard functionality (Optional) Programming functions: • Read/write eeprom and flash for: • Audi A6/Q7 EZS Kessy 9S12DB128/256 - immo datas decode INCLUDED • BMW EWS4, CAS2, CAS3, CAS3+, CAS4, CAS4+ • Land Rover/Jaguar KVM 9S12 2M35J/1M12S Mercedes all EZS Motorola 912/9S12 • Porsche BCM 9S12 5M48H, 1N35H, 1L15Y, 2M25J • Smart SAM 451 • VAG Group CDC 3217-3297 - immo datas decode INCLUDED Hardware: • MDPprog device • Power cable • Power supply unit • Click'n go adapter cable • Solder cable • 35080 adapter • Coaxial cable • USB+OTG Cable • Tablet • Magic Bench Connect EVO Lite • Smart Bench Right and Left cables • OBD Y cable • Magic Eraser cable • Universal Adapter for Magic Bench Connect EVO • Power Cable for Magic Bench Connect EVO Software: • MDPprog tablet software • Registration ЦЕНА: 1000 ЕВРО ( для всех участников форума ) 950 ЕВРО ( для форумчан с репутацией +50 ) MASTER CLASS, AutoChipBy, nikfm52 и 2 других 3 2 Ссылка на комментарий Поделиться на другие сайты Поделиться
Renault Electronic 2 411 Опубликовано 20 ноября, 2019 Автор Поделиться Опубликовано 20 ноября, 2019 MAGIC Bench Connect EVO Lite ЦЕНА: 420 ЕВРО ( для всех участников форума ) 400 ЕВРО ( для форумчан с репутацией +50 ) MASTER CLASS 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
Mb key 499 Опубликовано 19 сентября, 2020 Поделиться Опубликовано 19 сентября, 2020 В 20.11.2019 в 16:28, Renault Electronic сказал: АКТУАЛЬНЫЕ ЦЕНЫ УЗНАВАЙТЕ В ЛИЧНЫХ СООБЩНИЯХ!!! NEC KEY + ONLINE Показать контент NEC v.10.65 is a basic, start package for Mercedes-Benz key programming. Although it’s just a first step in Mercedes-Benz programming it has huge possibilities and allows to not only read/ erase/ program keys in cars but also do basic diagnostics on keys (like with the use of MB Key Expert). With the use of NEC PCB (included in the set) one can easily read/erase/write NEC processors used in Mercedes keys. If you work with older generation of keys, you can use MBE EEPROM programmer, to read/rease/write information in Motorola processors. Коллеги, на данный момент, мы договорились о скидке на девайсы от MBE Engineering. На сегодняшний день, вы можете приобрести их продукцию со скидкой (через форум carmasters.org). ЦЕНА 210 ЕВРО ( для всех участников форума ) 190 ЕВРО ( для форумчан с репутацией +50 ) MAXI - BGA + 204/207 Показать контент MB prog MAXI is an evolution with a special add-on of BGA/204/207 software, set of software and hardware that covers entire set of Mercedes keys programming. When we were designing MAXI kit set, we had in mind that when it comes to key programming, this set should cover not only new IR keys, but also transponder keys and first generation of IR keys (flip keys). MAXI kit contains not only key programming tools but also tools that allow erasing of the modules in Mercedes-Benz cars (including ECU’s and gearbox) and also testing on the bench. MAXI kit contains also emulators and one key, ready to be used. BGA At least one key MANUAL BGA All keys lost MANUAL BGA At least one key VIDEOMANUAL BGA All keys lost VIDEOMANUAL What is the most important add-on is a function that allows in an easy way, to read password and program keys in vehicles with BGA keys: Add key (at least one existing key), list below covers only BGA equipped vehicles W164 2009 + W166, W197 W212 W218 W246 W169 W209 W211 W172 W204 C207 W216 W221 W639 2009+ All key lost, list below covers only BGA equipped vehicles W204 C207 W166 W197 W212 W218 W246 All calculations for BGA keys are done on-line and internet connection is required; software works in pay-per-use way. It comes with 20 credits (20 password calculated). Set contains: HARDWARE: -MB Keyprog 2 EVO main adapter -IR Key Tools W204/W207 -MB Magic Eraser + connection cable -204/207 adapter -204/207 click 'n go -PCB adapter: DB9 main + 3 NEC PCB -USB cable -USB security dongle (may be included in MBKeyprog 2 Evo device, not seperately) -DATA flash memory card -NEC IC Socket -EEPROM Programmer -EIS/ESL Testing tool -MB Testing key -MBprog HC05/08/12 programmer -2 adapters: MC68HC05x32, MC68HC05E6 -MB 38 pin cable -ESL Emulator slim type -MB main OBD cable + OBD female power -BE key 433 or 315 Mhz -ESL NEC chip emulator -MB Coil detector -28 PIN clip -MB Keymaker SOFTWARE: -BGA software -204/207 software -Sonderhash account -NEC Prog v. 12 -IR Tools basic software -IR Tools EZS password reader -ESL/ELV Evo Prog -Eeprom programmer -Multiprog -ML Keymaker -MB Keyprog-2 v. 1.5 -MB Keyprog Lite v. 2.11 -MB Key Restorer -ECU CR1/2 Reader -IR Tools Advanced - Key Emulation -Online key calculation access -MB Magic Eraser software -MB PCF Keymaker (for ML device) -MB Truck Keymaker (for ML device) -Dodge Sprinter (for ML device) -20 credits Attention: if you have existing MBE Engineering set, you can contact us to update your set to work with BGA/204/207 vehicles. Contact us directly. ЦЕНА: 2200 ЕВРО ( для всех участников форума ) 2100 ЕВРО ( для форумчан с репутацией +50 ) MAGIC Bench Connect EVO Показать контент Magic Bench Connect EVO is a device that allows you to connect it to modules on bench in order to test their functionality. Other items in the package can can be connected to this device to extend the functionality. With MDPprog functions you can read/write EEPROM and Flash datas. Diagnostic functions: • Test modules on bench • Basic vehicle diagnostic tests • Read/Reset ECU/W204 ELV/Gearbox/ISM/DSM • Testing EIS and ELV on bench (Optional) • Test dashboard functionality (Optional) Programming functions: • Read/write eeprom and flash for: • Audi A6/Q7 EZS Kessy 9S12DB128/256 - immo datas decode INCLUDED • BMW EWS4, CAS2, CAS3, CAS3+, CAS4, CAS4+ • Land Rover/Jaguar KVM 9S12 2M35J/1M12S Mercedes all EZS Motorola 912/9S12 • Porsche BCM 9S12 5M48H, 1N35H, 1L15Y, 2M25J • Smart SAM 451 • VAG Group CDC 3217-3297 - immo datas decode INCLUDED Hardware: • MDPprog device • Power cable • Power supply unit • Click'n go adapter cable • Solder cable • 35080 adapter • Coaxial cable • USB+OTG Cable • Tablet • Magic Bench Connect EVO Lite • Smart Bench Right and Left cables • OBD Y cable • Magic Eraser cable • Universal Adapter for Magic Bench Connect EVO • Power Cable for Magic Bench Connect EVO Software: • MDPprog tablet software • Registration ЦЕНА: 1000 ЕВРО ( для всех участников форума ) 950 ЕВРО ( для форумчан с репутацией +50 ) Я хочу купить на Объясните поподробней Вот это 190 евро аппаратов что можно сделать Ссылка на комментарий Поделиться на другие сайты Поделиться
Renault Electronic 2 411 Опубликовано 19 сентября, 2020 Автор Поделиться Опубликовано 19 сентября, 2020 38 минут назад, Mb key сказал: Я хочу купить на Объясните поподробней Вот это 190 евро аппаратов что можно сделать Ключи для MB на Motorola и NEC. Ссылка на комментарий Поделиться на другие сайты Поделиться
Mb key 499 Опубликовано 19 сентября, 2020 Поделиться Опубликовано 19 сентября, 2020 19 минут назад, Renault Electronic сказал: Ключи для MB на Motorola и NEC. Понятно доставка Азербайджана город Баку сможете сделать и ещё если будет возможности Дайте полностью описание хочу прочитать Ещё в offline режиме будет работать если не будет онлайн Ссылка на комментарий Поделиться на другие сайты Поделиться
Renault Electronic 2 411 Опубликовано 19 сентября, 2020 Автор Поделиться Опубликовано 19 сентября, 2020 Пишите в личку. Ссылка на комментарий Поделиться на другие сайты Поделиться
Mb key 499 Опубликовано 19 сентября, 2020 Поделиться Опубликовано 19 сентября, 2020 Только что, Renault Electronic сказал: Пишите в личку. Ok Ссылка на комментарий Поделиться на другие сайты Поделиться
joroflash 7 Опубликовано 6 апреля, 2021 Поделиться Опубликовано 6 апреля, 2021 Спасибо за ответа ! А для BGA ключей , update 2 from MBE , там надо купить токен за 50 евро , что би пользоватья , а етим получается неконкурентная цена . Существует ли софтуер . которим можно считать кое что полезное для пересчета пароля от BGA ключика или от NEC EIS . Остал с впечатления от описание MBE BGA software , чтоби работал , надо войти в Sonderhash акаунта О прогерах VVDI MB и CGDI знаем, там ясно , а я пользуюсь NEC12 от MBE , для ключей до BGA . Ссылка на комментарий Поделиться на другие сайты Поделиться
Mb key 499 Опубликовано 7 апреля, 2021 Поделиться Опубликовано 7 апреля, 2021 10 часов назад, joroflash сказал: CGDI знаем, 👍🔥💯💯 Ссылка на комментарий Поделиться на другие сайты Поделиться
Kef 50 Опубликовано 9 апреля, 2021 Поделиться Опубликовано 9 апреля, 2021 В 06.04.2021 в 22:04, joroflash сказал: пользуюсь NEC12 от MBE , для ключей до BGA . Он новый ключ на Nec не BGA по инфракрасному каналу записывает? Ссылка на комментарий Поделиться на другие сайты Поделиться
joroflash 7 Опубликовано 9 апреля, 2021 Поделиться Опубликовано 9 апреля, 2021 Ну да , отлично справляется . Обнуляет Нека , 51 и 57 читает дампа , записивает, стирает и Нек и ВЕ китайские черес инфраред , вичисляет офлайн ключики , парол витаскивает через инфраред от ЕИС от 203 и там какие то указани . Kef 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
Kef 50 Опубликовано 9 апреля, 2021 Поделиться Опубликовано 9 апреля, 2021 Супер! Спасибо! Ссылка на комментарий Поделиться на другие сайты Поделиться
johnny 32 Опубликовано 9 апреля, 2021 Поделиться Опубликовано 9 апреля, 2021 3 часа назад, joroflash сказал: Ну да , отлично справляется . Обнуляет Нека , 51 и 57 читает дампа , записивает, стирает и Нек и ВЕ китайские черес инфраред , вичисляет офлайн ключики , парол витаскивает через инфраред от ЕИС от 203 и там какие то указани . 908 мотороллы, ir tools advanced делает, с остальными замками, особо ничего не может Ссылка на комментарий Поделиться на другие сайты Поделиться
joroflash 7 Опубликовано 10 апреля, 2021 Поделиться Опубликовано 10 апреля, 2021 Я ,купил етот оригиналний тул по отличной цене от колега мой , 203 довольно неприятний для разборки , так ,что спасибо автору , второе - работает в офлайн , а не всегда для cgdi можеш работать онлайн,когда тебе нужно например . Надоело от инструменти , которие работют наполовине от заявленное , не имеют адекватной поддержки и руководства нормальние , но ви все ето знаете , коллеги . Есть вороси - пишем техподдержку , вам не только ответили , но и черес Anydesk дистанционно оказало содействие , не мог представит китайские товарищи в подобном ситуацией ... ну Если цена одного токена сделают более доступна, то и для бга возму ъпгрейда от MBE engineering . Ссылка на комментарий Поделиться на другие сайты Поделиться
димас т 319 Опубликовано 26 сентября, 2022 Поделиться Опубликовано 26 сентября, 2022 В 20.11.2019 в 14:28, Renault Electronic сказал: АКТУАЛЬНЫЕ ЦЕНЫ УЗНАВАЙТЕ В ЛИЧНЫХ СООБЩНИЯХ!!! NEC KEY + ONLINE Показать контент NEC v.10.65 is a basic, start package for Mercedes-Benz key programming. Although it’s just a first step in Mercedes-Benz programming it has huge possibilities and allows to not only read/ erase/ program keys in cars but also do basic diagnostics on keys (like with the use of MB Key Expert). With the use of NEC PCB (included in the set) one can easily read/erase/write NEC processors used in Mercedes keys. If you work with older generation of keys, you can use MBE EEPROM programmer, to read/rease/write information in Motorola processors. Коллеги, на данный момент, мы договорились о скидке на девайсы от MBE Engineering. На сегодняшний день, вы можете приобрести их продукцию со скидкой (через форум carmasters.org). ЦЕНА 210 ЕВРО ( для всех участников форума ) 190 ЕВРО ( для форумчан с репутацией +50 ) MAXI - BGA + 204/207 Показать контент MB prog MAXI is an evolution with a special add-on of BGA/204/207 software, set of software and hardware that covers entire set of Mercedes keys programming. When we were designing MAXI kit set, we had in mind that when it comes to key programming, this set should cover not only new IR keys, but also transponder keys and first generation of IR keys (flip keys). MAXI kit contains not only key programming tools but also tools that allow erasing of the modules in Mercedes-Benz cars (including ECU’s and gearbox) and also testing on the bench. MAXI kit contains also emulators and one key, ready to be used. BGA At least one key MANUAL BGA All keys lost MANUAL BGA At least one key VIDEOMANUAL BGA All keys lost VIDEOMANUAL What is the most important add-on is a function that allows in an easy way, to read password and program keys in vehicles with BGA keys: Add key (at least one existing key), list below covers only BGA equipped vehicles W164 2009 + W166, W197 W212 W218 W246 W169 W209 W211 W172 W204 C207 W216 W221 W639 2009+ All key lost, list below covers only BGA equipped vehicles W204 C207 W166 W197 W212 W218 W246 All calculations for BGA keys are done on-line and internet connection is required; software works in pay-per-use way. It comes with 20 credits (20 password calculated). Set contains: HARDWARE: -MB Keyprog 2 EVO main adapter -IR Key Tools W204/W207 -MB Magic Eraser + connection cable -204/207 adapter -204/207 click 'n go -PCB adapter: DB9 main + 3 NEC PCB -USB cable -USB security dongle (may be included in MBKeyprog 2 Evo device, not seperately) -DATA flash memory card -NEC IC Socket -EEPROM Programmer -EIS/ESL Testing tool -MB Testing key -MBprog HC05/08/12 programmer -2 adapters: MC68HC05x32, MC68HC05E6 -MB 38 pin cable -ESL Emulator slim type -MB main OBD cable + OBD female power -BE key 433 or 315 Mhz -ESL NEC chip emulator -MB Coil detector -28 PIN clip -MB Keymaker SOFTWARE: -BGA software -204/207 software -Sonderhash account -NEC Prog v. 12 -IR Tools basic software -IR Tools EZS password reader -ESL/ELV Evo Prog -Eeprom programmer -Multiprog -ML Keymaker -MB Keyprog-2 v. 1.5 -MB Keyprog Lite v. 2.11 -MB Key Restorer -ECU CR1/2 Reader -IR Tools Advanced - Key Emulation -Online key calculation access -MB Magic Eraser software -MB PCF Keymaker (for ML device) -MB Truck Keymaker (for ML device) -Dodge Sprinter (for ML device) -20 credits Attention: if you have existing MBE Engineering set, you can contact us to update your set to work with BGA/204/207 vehicles. Contact us directly. ЦЕНА: 2200 ЕВРО ( для всех участников форума ) 2100 ЕВРО ( для форумчан с репутацией +50 ) MAGIC Bench Connect EVO Показать контент Magic Bench Connect EVO is a device that allows you to connect it to modules on bench in order to test their functionality. Other items in the package can can be connected to this device to extend the functionality. With MDPprog functions you can read/write EEPROM and Flash datas. Diagnostic functions: • Test modules on bench • Basic vehicle diagnostic tests • Read/Reset ECU/W204 ELV/Gearbox/ISM/DSM • Testing EIS and ELV on bench (Optional) • Test dashboard functionality (Optional) Programming functions: • Read/write eeprom and flash for: • Audi A6/Q7 EZS Kessy 9S12DB128/256 - immo datas decode INCLUDED • BMW EWS4, CAS2, CAS3, CAS3+, CAS4, CAS4+ • Land Rover/Jaguar KVM 9S12 2M35J/1M12S Mercedes all EZS Motorola 912/9S12 • Porsche BCM 9S12 5M48H, 1N35H, 1L15Y, 2M25J • Smart SAM 451 • VAG Group CDC 3217-3297 - immo datas decode INCLUDED Hardware: • MDPprog device • Power cable • Power supply unit • Click'n go adapter cable • Solder cable • 35080 adapter • Coaxial cable • USB+OTG Cable • Tablet • Magic Bench Connect EVO Lite • Smart Bench Right and Left cables • OBD Y cable • Magic Eraser cable • Universal Adapter for Magic Bench Connect EVO • Power Cable for Magic Bench Connect EVO Software: • MDPprog tablet software • Registration ЦЕНА: 1000 ЕВРО ( для всех участников форума ) 950 ЕВРО ( для форумчан с репутацией +50 ) может что в наличии есть на продажу ? Ссылка на комментарий Поделиться на другие сайты Поделиться
Renault Electronic 2 411 Опубликовано 27 сентября, 2022 Автор Поделиться Опубликовано 27 сентября, 2022 8 часов назад, димас т сказал: может что в наличии есть на продажу ? А что надо? 😉 Ссылка на комментарий Поделиться на другие сайты Поделиться
димас т 319 Опубликовано 27 сентября, 2022 Поделиться Опубликовано 27 сентября, 2022 2 часа назад, Renault Electronic сказал: А что надо? 😉 NEC KEY + ONLINE Ссылка на комментарий Поделиться на другие сайты Поделиться
Serhii621 59 Опубликовано 10 июня, 2023 Поделиться Опубликовано 10 июня, 2023 Добрый день есть в продпже nec key+online Ссылка на комментарий Поделиться на другие сайты Поделиться
ruta 0 Опубликовано 3 апреля Поделиться Опубликовано 3 апреля Ещё есть? Ссылка на комментарий Поделиться на другие сайты Поделиться
