jemilalicheroy 37 Опубликовано 15 мая, 2021 Поделиться Опубликовано 15 мая, 2021 Spoiler FORD M SERIES RADIO CODE DECODER How to find your radio serial: Method 1: Hold buttons 1 & 6 together, if the serial did not show, try holding buttons 2 & 6 and look for a serial starting with the letter 'M' For example M123456. If neither of these work please refer to method 2 below. ... Method2: Some model is old and does not show the serial on the screen, so you must remove the stereo unit. You can see it on the case top and side sticker. How To Enter Ford Radio Code: Enter the radio code when you see four horizontal lines on the display screen. If you see the word wait, you need to leave the radio switched on for up to 1 hour this will allow the radio to reset.If LOCKED 10 is on-screen just press and hold the preset button 6 whilst turning the radio on this will give you 3 final attempts to enter the correct code. If your radio is displays LOCKED 13 then the code will be of no use as this radio would need to be manually decoded. Example of code input: Press 1 repeatedly for the first digit of your code. Press 2 repeatedly for the second digit of your code. Press 3 repeatedly for the third digit of your code. Press 4 repeatedly for the fourth digit of your code. Once your radio code is showing on the display press & hold the number 5 button until you hear an confirmation beep. >>>>> PM FOR PASS <<<<< thank you FORD M SERIES RADIO CODE.zip download (1).jfif download.jfif shadows и bashka_mc 2 Ссылка на комментарий Поделиться на другие сайты Поделиться
Sedoy34 235 Опубликовано 16 мая, 2021 Поделиться Опубликовано 16 мая, 2021 В личку за паролем это чтобы репу заработать? Вот сам калькулятор без паролей и хождения по личкам fordmseries.7z bashka_mc, shadows, zkf и 1 другой 4 Ссылка на комментарий Поделиться на другие сайты Поделиться
Paulyd 212 Опубликовано 16 мая, 2021 Поделиться Опубликовано 16 мая, 2021 Эту кальку легко найти на просторах нета. Эту кальку легко найти на просторах нета. Ссылка на комментарий Поделиться на другие сайты Поделиться
AvtoDym 757 Опубликовано 16 мая, 2021 Поделиться Опубликовано 16 мая, 2021 9 часов назад, jemilalicheroy сказал: Показать контент FORD M SERIES RADIO CODE DECODER How to find your radio serial: Method 1: Hold buttons 1 & 6 together, if the serial did not show, try holding buttons 2 & 6 and look for a serial starting with the letter 'M' For example M123456. If neither of these work please refer to method 2 below. ... Method2: Some model is old and does not show the serial on the screen, so you must remove the stereo unit. You can see it on the case top and side sticker. How To Enter Ford Radio Code: Enter the radio code when you see four horizontal lines on the display screen. If you see the word wait, you need to leave the radio switched on for up to 1 hour this will allow the radio to reset.If LOCKED 10 is on-screen just press and hold the preset button 6 whilst turning the radio on this will give you 3 final attempts to enter the correct code. If your radio is displays LOCKED 13 then the code will be of no use as this radio would need to be manually decoded. Example of code input: Press 1 repeatedly for the first digit of your code. Press 2 repeatedly for the second digit of your code. Press 3 repeatedly for the third digit of your code. Press 4 repeatedly for the fourth digit of your code. Once your radio code is showing on the display press & hold the number 5 button until you hear an confirmation beep. >>>>> PM FOR PASS <<<<< thank you FORD M SERIES RADIO CODE.zip 275 \u0411 · 2 загрузки download (1).jfif 9 \u043a\u0411 · 2 загрузки download.jfif 8 \u043a\u0411 · 2 загрузки WTF??? Ссылка на комментарий Поделиться на другие сайты Поделиться
shatei 52 Опубликовано 16 мая, 2021 Поделиться Опубликовано 16 мая, 2021 ТС хотел получить хоть какой-то донат в свою пользу, а тут весь план разрушили 1 час назад, AvtoDym сказал: WTF??? Ссылка на комментарий Поделиться на другие сайты Поделиться
Paulyd 212 Опубликовано 16 мая, 2021 Поделиться Опубликовано 16 мая, 2021 Ага тут вчера один отлом проги по грузовикам 2020 года толкал говорил пароль только после оплаты так его быстро на чистую воду вывели. Ссылка на комментарий Поделиться на другие сайты Поделиться
jemilalicheroy 37 Опубликовано 16 мая, 2021 Автор Поделиться Опубликовано 16 мая, 2021 please remove the negative reputation i will post the password on the comment i'm sorry if i was a bad companion my only intentions was to be a good mate on helping each other i & thought this forum upload rules was like the other forum rules anyways... PASSWORD:7569 AvtoDym 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
AvtoDym 757 Опубликовано 16 мая, 2021 Поделиться Опубликовано 16 мая, 2021 57 минут назад, jemilalicheroy сказал: please remove the negative reputation i will post the password on the comment i'm sorry if i was a bad companion my only intentions was to be a good mate on helping each other i & thought this forum upload rules was like the other forum rules anyways... PASSWORD:7569 if you wanted to be a companion, give information that is not here on the forum Ссылка на комментарий Поделиться на другие сайты Поделиться
jemilalicheroy 37 Опубликовано 16 мая, 2021 Автор Поделиться Опубликовано 16 мая, 2021 32 minutes ago, AvtoDym said: if you wanted to be a companion, give information that is not here on the forum ok i will try my best next time Ссылка на комментарий Поделиться на другие сайты Поделиться
