prommast 141 Опубликовано 28 сентября, 2019 Поделиться Опубликовано 28 сентября, 2019 Столкнулся с задачей - добавить брелоков в память авто. На фото мои зверьки. Ни кто из знакомых не подсказал как решить вопрос. Нашел на забугорных сайтах инструкцию. В принципе у всех gm брелоки пишутся при помощи танцев с бубнами вокруг авто) Прилогаю один из вариантов. Так же не понял, что за моторола, модет кто подскажет как и чем ее читать? The Oldsmobile Alero was available as a sedan or a coup with a 140 horsepower 4-cylinder or 170-horsepower 6-cylinder engine. Most models of the Aleros included a keyless entry system, which allowed you to lock and unlock the doors without physically inserting the key into the door. If you replace the batteries in your keypad, or purchase a new keypad, you must reprogram the keypad to your particular Alero. Programming the keypad is a simple process, provided you follow the proper procedure. Step 1 Sit in the driver's seat of the Alero and close all of the doors. Step 2 Insert the key into the ignition and turn it to the "On" position, then return to the "Off" position. Step 3 Remove the key from the ignition. Step 4 Press and hold the door "Unlock" button on the driver's side door handle. Continue holding the "Unlock" button while the next steps are completed. Step 5 Insert the key into the ignition, then remove it. Ensure that the ignition remains in the "Off" position. Step 6 Insert the key into the ignition once again, then remove. Again, ensure that the ignition remains in the "Off" position. Step 7 Insert the key into the ignition, then release the "Unlock" button. The vehicle's horn will sound three times, indicating that the vehicle has entered "Program Mode." Step 8 Press and hold both the "Lock" and "Unlock" buttons on the keypad that you would like to program. Continue to hold the buttons until the vehicle's horn sounds two times, which will take approximately 15 seconds. Repeat this step for each additional keypad that you would like to program. Remove the key from the ignition to complete the programming process. Items you will need Vehicle key Мастак 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
dimasony 985 Опубликовано 28 сентября, 2019 Поделиться Опубликовано 28 сентября, 2019 Ну авто уже Америкос, уже хорошо. Вот бы год узнать. И ключ с чипом? Ссылка на комментарий Поделиться на другие сайты Поделиться
prommast 141 Опубликовано 28 сентября, 2019 Автор Поделиться Опубликовано 28 сентября, 2019 2002 год. На последнем фото микруха, стоящая в брелке. в нагрузку оставлю фотки донорских блоков с разборки под это авто. Клиент брал на всякий случай. Ссылка на комментарий Поделиться на другие сайты Поделиться
dimasony 985 Опубликовано 28 сентября, 2019 Поделиться Опубликовано 28 сентября, 2019 И кстати, это брелки кодилак. Попробуйте найти инструкцию на кодилак. Ссылка на комментарий Поделиться на другие сайты Поделиться
prommast 141 Опубликовано 28 сентября, 2019 Автор Поделиться Опубликовано 28 сентября, 2019 За наводку спасибо! Пока все норм. Я решил поделиться наработкой. Ссылка на комментарий Поделиться на другие сайты Поделиться
dimasony 985 Опубликовано 28 сентября, 2019 Поделиться Опубликовано 28 сентября, 2019 Вообще проблемы с редкими брелка и я решаю через kd-x2. Отличная штука в этом вопросе. Даже поидее может решить проблему с xc90 при наличии одного ключа) Ссылка на комментарий Поделиться на другие сайты Поделиться
Absurdyx 259 Опубликовано 29 сентября, 2019 Поделиться Опубликовано 29 сентября, 2019 21 час назад, dimasony сказал: Вообще проблемы с редкими брелка и я решаю через kd-x2. Отличная штука в этом вопросе. Даже поидее может решить проблему с xc90 при наличии одного ключа) Блин Димон, губу на хц 90 раскатал.... не забывай что при копировании ремоута, часто родной отваливается...и как. Ы будешь обратно это писать? Там столкнёшься с недопониманием... Что касается ГМ в целом...то через лаунч прекрасно ремоуты добавляются...Выберите ГМ...ва потом конкретно марку и модель.... Ссылка на комментарий Поделиться на другие сайты Поделиться
