Is R270 able to reprogram FRM modules?
loshiq_ismail
Hi all,
The title basically says it all. I wanna know which FRM versions is the R270 able to reprogram. And is it possible to modify it in order to be able to program all FRM modules.
Thanks!
31 минуту назад, loshiq_ismail сказал:
Thanks! I'm on a budget, so what is the cheapest programmer that can repair all FRM modules?
R270
I already have an R270. lemantovi4 said it can program FRM2, but what about FRM3? Is the R270 able to program it, or should I get another programmer?
4 часа назад, loshiq_ismail сказал:
Спасибо! У меня ограниченный бюджет, поэтому посоветуйте, какой самый дешевый программатор сможет отремонтировать все модули FRM?
Xpog
Вы не понимаете суть проблемы. R270 предназначен для работы с иммо, но FRM он тоже зачитает, только разметку dflash не сделает.
I need something to rewrite the EEPROM. I have a tool that will reconstruct the EEPROM from DFLASH. So will R270 write to FRM3, or should I get an xprog?
Also, will xprog v5.55 work? Or should I get a newer version?
