Kalle 0 Опубликовано 26 октября, 2023 Поделиться Опубликовано 26 октября, 2023 Easy Renault 6.1.4 Details: Simple Renault V _ Specialize diagnostic software for Renault/Dacia vehicles. This allows you to communicate with your vehicle diagnose a fault and turn off the drain indicator on the instrument panel. Airbag reset, steering assist reset , learning ECM/locking column etc. and other useful operations for the professionals. For updates/support or other information please contact to us. The software can be used by people who do not have special knowledge in the field of electronics or computers, and their simple menu eliminates the need to study thick textbooks. Very easy to use and high functionality. ................................................ . .......................................... Easy Renault activation procedure: 1 Download Easy Renault PreActivator. Extract and save to your desktop. 2. Plug your ObdLink cable into the USB port, launch Easy Renault PreActivator.exe and click Generate File. (If you receive a message that generation is not possible, run the executable as administrator.) Your generated file should be named /Easy Renault.txt. It is located in the same location as your Easy Renault Preactivator executable file. 3. Email us the file with your name to appear on the main screen and your email address. 4. You will receive an email with the download link and can run Easy Renault V 6.1.4. 5. If you have any installation problems, simply report it ................................................ . ................................................ .. . Further details: Send me a PM. V/CAPTUR II Change VIN Delete DF 002 Clear Anti Start Code Repair Block - Anti Version Version Last DAE CLIO III / MODE [EEPROM 24C16] for Power Steering -CRCs for ECM SIEMENS EMS3132 / SIRIUS 32N [ WITH CAN ] Old versions 31H / EMS3132 [ SANS - CAN Version ] I Ph2] Learning key/Blank UCH Calculate pin code from UCH file Calculate pin code from key code Blank UCH function BOOT -MODE MC68HC(7)05B32 read MC68HC(7)05B32 write Ссылка на комментарий Поделиться на другие сайты Поделиться
feufollet 0 Опубликовано 13 ноября, 2023 Поделиться Опубликовано 13 ноября, 2023 У вас есть ссылка, пожалуйста? Ссылка на комментарий Поделиться на другие сайты Поделиться
Kalle 0 Опубликовано 16 декабря, 2023 Автор Поделиться Опубликовано 16 декабря, 2023 В 13.11.2023 в 14:02, feufollet сказал: Haben Sie bitte einen Link? Sure, you have a PM Ссылка на комментарий Поделиться на другие сайты Поделиться
Maloy Krsk 10 Опубликовано 26 декабря, 2023 Поделиться Опубликовано 26 декабря, 2023 Hi! does this software work with ELS27? Ссылка на комментарий Поделиться на другие сайты Поделиться
Kalle 0 Опубликовано 13 января, 2024 Автор Поделиться Опубликовано 13 января, 2024 В 26.12.2023 в 07:49, gdata сказал: Hallo! Funktioniert diese Software mit ELS27? Yes Ссылка на комментарий Поделиться на другие сайты Поделиться
Tonyracing81 1 Опубликовано 11 марта, 2024 Поделиться Опубликовано 11 марта, 2024 grazie Ссылка на комментарий Поделиться на другие сайты Поделиться
fanka 1 Опубликовано 24 апреля, 2024 Поделиться Опубликовано 24 апреля, 2024 привет , можно и мне ссылку ? Ссылка на комментарий Поделиться на другие сайты Поделиться
Saniksanik 25 Опубликовано 2 июля Поделиться Опубликовано 2 июля Тоже бы не помешала ссылка, хоть посмотреть что за зверь Ссылка на комментарий Поделиться на другие сайты Поделиться
Плутон 6 Опубликовано 24 октября Поделиться Опубликовано 24 октября установил, все вроде активировал но с адаптером VLinker FS USB adapter China запустить не могу... Хотя сам Ренолинк с ним отлично работает. Какой адаптер ей нужен. Есть у меня еще ELS27 и SX_RenOLink187 Easy Renault V6.1.4 купил.rarвот этот софт я купил у китайцев на Алиэкспресс Ссылка на комментарий Поделиться на другие сайты Поделиться
Saniksanik 25 Опубликовано 24 октября Поделиться Опубликовано 24 октября Ну приборку оно видит при красном китайском шнурке . Больше на столе ничего нет. Но прога была бы на английском хотя бы... а так ничерта непонятно, в блок ключей на реальном авто я таким чудом не полезу Ссылка на комментарий Поделиться на другие сайты Поделиться
Maloy Krsk 10 Опубликовано 14 часов назад Поделиться Опубликовано 14 часов назад В 25.10.2025 в 00:00, Плутон сказал: установил, все вроде активировал но с адаптером VLinker FS USB adapter China запустить не могу... Хотя сам Ренолинк с ним отлично работает. Какой адаптер ей нужен. Есть у меня еще ELS27 и SX_RenOLink187 Easy Renault V6.1.4 купил.rarвот этот софт я купил у китайцев на Алиэкспресс Приветствую! паролем не поделитесь? Ссылка на комментарий Поделиться на другие сайты Поделиться
Shi 126 Опубликовано 8 часов назад Поделиться Опубликовано 8 часов назад Easy Renault 6.1.4 Software for Renault Full_autosoftos.com.rarбез пароля.. сам ещё не пробовал. Ссылка на комментарий Поделиться на другие сайты Поделиться
Maloy Krsk 10 Опубликовано 8 часов назад Поделиться Опубликовано 8 часов назад 18 минут назад, Shi сказал: Easy Renault 6.1.4 Software for Renault Full_autosoftos.com.rarбез пароля.. сам ещё не пробовал. там тоже активация как на ренолик? Ссылка на комментарий Поделиться на другие сайты Поделиться
Shi 126 Опубликовано 7 часов назад Поделиться Опубликовано 7 часов назад 53 минуты назад, Maloy Krsk сказал: там тоже активация как на ренолик? х\з.. я ещё не устанавливал.. Ссылка на комментарий Поделиться на другие сайты Поделиться
