Гость catala20032004 Опубликовано 7 октября, 2013 Поделиться Опубликовано 7 октября, 2013 Подскажите, как с помощью VCDS или аналогичного сканера можно программно отключить сигнализацию о непристегнутых ремнях безопасности? Ссылка на комментарий Поделиться на другие сайты Поделиться
SiderMan 22 Опубликовано 13 октября, 2013 Поделиться Опубликовано 13 октября, 2013 Steering weight 44 – Steering assist 10 - Adaption Channel 1 Should read 5 on non Vrs models. Pick a number between 1 & 6 for steering weight For auto lights DISCLAIMER: you need rain sensor wipers for this. Coding does not work on all cars 09 – Central electrics Long coding (07) , click yes when asked Byte 1 – highlight ‘assistance driving light_leaving home active’and ‘coming home active.’ Transfer coding. Single door unlock 46 – central convenience 10 - Adaption Channel 3 1= on, 0=off Anti hijack Auto lock 46 – central convenience 10 - Adaption Channel 4 1= on, 0=off Auto unlock (when you take keys out of ignition) 46 – central convenience 10 - Adaption Channel 5 1= on, 0=off Alarm horn change 46 – central convenience 10 - Adaption Channel 13 1= Rest of world 2=UK Instument options 17 – instruments 07 – recode 00??x0x ??= 00 = no options +01 = brake pad monitoring +02 = Seat belt warning +04 = Washer fluid warning (add the option numbers together for the right number i.e: all three = 07 or to turn off seatbelt warning 01+04=05) Long coding options (other stuff is possible, but either not worth it or a bit dodgy) Central electrics (09) (Long coding options) Byte 1 Scandinavian lights (always on) North America lights (front lights on with handbrake off) Leaving home lights (lights come on for 60 secs when door is unlocked) Coming home lights (lights come on for 60 ses when door is locked) (for some reason I cannot get this to work) Byte 3 Rear fog lights (highlight for 1, turn off for 2) (1 foglight is dependent on left or right hand drive) Reverse lights (same as rear fogs, single reverse light opposite side to single fog lights like with cars with one of each) Reverse driving lights off when boot open (don’t see the point apart from saving the bulb) Byte 4 Activation of 2 rear fogs Byte 17 Emergency brake light flash active (not tried it, but some Peugeots have it, when the brakes are put on hard the brake light flashes) Front fogs deactivated with main beam (With Fog lamps on, the turn off when main beam is switched on) 46 – Central convenience long coding Byte1 Single door opening Auto lock Auto unlock Byte 4 Power window open and close by for or key (on and off) Byte 6 Unlock beeps and indicator blink through key and remote Byte 7 Lock beeps and indicator blink through key and remote Byte 8 Activation of anti theft warning system with beeps and blinks Byte 9 Synchronised mirror adjustment (turns on and off the right side mirror adjuster moving both mirrors) Byte 11 Siren tone type (on = Rest of world, off = Uk ) Alarm siren type ( on=short length, off= long Ссылка на комментарий Поделиться на другие сайты Поделиться
vigen2010 9 Опубликовано 9 января, 2014 Поделиться Опубликовано 9 января, 2014 вики.росс-тецх. Подскажите, как с помощью VCDS или аналогичного сканера можно программно отключить сигнализацию о непристегнутых ремнях безопасности?заходи на росс теч. там все есть Ссылка на комментарий Поделиться на другие сайты Поделиться
Slava 0 Опубликовано 16 февраля, 2014 Поделиться Опубликовано 16 февраля, 2014 измени кодировку в щитке и будет тебе счастье Ссылка на комментарий Поделиться на другие сайты Поделиться
ВАМ 683 Опубликовано 21 февраля, 2014 Поделиться Опубликовано 21 февраля, 2014 Oт первого двузначного числа отними 2 и закодируй. Пример бало 21098 надо 19098 Ссылка на комментарий Поделиться на другие сайты Поделиться
rasspy 9 Опубликовано 30 марта, 2014 Поделиться Опубликовано 30 марта, 2014 Первое число там максимум 07 (01 - уровень омывайки; 02-ремни; 04-колодки) Ссылка на комментарий Поделиться на другие сайты Поделиться
abdel 3 Опубликовано 30 марта, 2014 Поделиться Опубликовано 30 марта, 2014 hi, Alarm is now save on 09 central electics not channel 46 anymore Ссылка на комментарий Поделиться на другие сайты Поделиться
Leon317 56 Опубликовано 31 марта, 2014 Поделиться Опубликовано 31 марта, 2014 Первое число там максимум 07 (01 - уровень омывайки; 02-ремни; 04-колодки)Поставьте 00 и будет без ремней и всего остального... Ссылка на комментарий Поделиться на другие сайты Поделиться
Leon317 56 Опубликовано 31 марта, 2014 Поделиться Опубликовано 31 марта, 2014 Первое число там максимум 07 (01 - уровень омывайки; 02-ремни; 04-колодки)Поставьте 00 и будет без ремней и всего остального...Где бред просто если изменить кодировку то часто в приборе перестает показвать колодки омывачку, но и конечно ремни... Ссылка на комментарий Поделиться на другие сайты Поделиться
lbotos 143 Опубликовано 10 июня, 2014 Поделиться Опубликовано 10 июня, 2014 Я на Octavia II отсоединял разьем под сидением. Ссылка на комментарий Поделиться на другие сайты Поделиться
dpeleectric 0 Опубликовано 20 августа, 2014 Поделиться Опубликовано 20 августа, 2014 правильно отсоедени разъем или обманку поставь АлександрЗамесин 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
rola1971 10 Опубликовано 14 сентября, 2014 Поделиться Опубликовано 14 сентября, 2014 liegcie postavit obmanku i vsio Ссылка на комментарий Поделиться на другие сайты Поделиться
KIPKOT 23 Опубликовано 14 сентября, 2014 Поделиться Опубликовано 14 сентября, 2014 Отсоедини провода идущие к замку ремня, Ссылка на комментарий Поделиться на другие сайты Поделиться
orlsn 2 Опубликовано 9 октября, 2014 Поделиться Опубликовано 9 октября, 2014 правильно отсоедени разъем или обманку поставь Да уж совет , если поставить обманку и не пристегнутся ремнями,то подушка сработает на все 100% . При не пристегнутом ремни ,подушка сработает процентов на тридцать. При аварии у вас или шея сломана или мозги в кучку. Ссылка на комментарий Поделиться на другие сайты Поделиться
hor 21 Опубликовано 2 ноября, 2014 Поделиться Опубликовано 2 ноября, 2014 однозначно через кодировку приборки Ссылка на комментарий Поделиться на другие сайты Поделиться
АлександрЗамесин 8 Опубликовано 26 ноября, 2014 Поделиться Опубликовано 26 ноября, 2014 правильно отсоедени разъем или обманку поставь Вот единственно верное решение. Не нужно электронику насиловать. Обманку воткнул и все. bait 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
bait 157 Опубликовано 26 ноября, 2014 Поделиться Опубликовано 26 ноября, 2014 Вот единственно верное решение. Не нужно электронику насиловать. Обманку воткнул и все. Такое может сказать человек, который боится и не понимает её (электронику) Ссылка на комментарий Поделиться на другие сайты Поделиться
Dimatkz777 0 Опубликовано 15 декабря, 2014 Поделиться Опубликовано 15 декабря, 2014 А ещё лучше - пристёгивайся, так безопаснее Ссылка на комментарий Поделиться на другие сайты Поделиться
