Товары с Aliexpress
GarageS
Хорошая штукенция для диагнозы и измерения уровней протоколов на авто при подключенном сканере - https://ru.aliexpress.com/item/30-OBD2-OBDII-J1962-y-16-pin-Splitter/32838159012.html?spm=a2g0s.9042311.0.0.JsBoIJ
Вот еще партия наборов по 1.20$  :dada:
https://www.aliexpress.com/item/New-Finether-30-PCS-Hand-Tools-Socket-Screwdriver-Sets-Multifunction-Repair-Tool-Carbon-Steel-Sockets-Repairs/32838501163.html?spm=2114.search0104.3.64.3iQWKj&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10344_10345_10342_10343_10340_10341_10543_10541_10307_10301_10060_10155_10154_10056_10055_10539_10537_10536_10059_10534_10533_100031_10103_10102_5670011_10169_10142_10107_5660011_10562_5740011_10084_10083_10561_10312_10313_10314_10550_10073_10551_10552_10553_10554_10557_5650011,searchweb201603_30,ppcSwitch_5&btsid=60d39259-cffc-47f1-8580-583c22469895&algo_expid=8ffdf214-4db8-41c0-b806-73d0a39ffc54-9&algo_pvid=8ffdf214-4db8-41c0-b806-73d0a39ffc54
https://www.aliexpress.com/item/New-Finether-40-PCS-Socket-and-Bit-Set-Drive-Socket-Wrench-Multifunction-Hand-Tools-Carbon-Steel/32841023014.html?spm=2114.search0104.3.71.3iQWKj&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10344_10345_10342_10343_10340_10341_10543_10541_10307_10301_10060_10155_10154_10056_10055_10539_10537_10536_10059_10534_10533_100031_10103_10102_5670011_10169_10142_10107_5660011_10562_5740011_10084_10083_10561_10312_10313_10314_10550_10073_10551_10552_10553_10554_10557_5650011,searchweb201603_30,ppcSwitch_5&btsid=60d39259-cffc-47f1-8580-583c22469895&algo_expid=8ffdf214-4db8-41c0-b806-73d0a39ffc54-10&algo_pvid=8ffdf214-4db8-41c0-b806-73d0a39ffc54
https://www.aliexpress.com/item/New-Finether-28-PCS-Precision-Screwdriver-Set-Multifunction-Repair-Tools-Mini-tool-Screwdrivers-For-precision-machinery/32840995828.html?spm=2114.search0104.3.85.3iQWKj&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10344_10345_10342_10343_10340_10341_10543_10541_10307_10301_10060_10155_10154_10056_10055_10539_10537_10536_10059_10534_10533_100031_10103_10102_5670011_10169_10142_10107_5660011_10562_5740011_10084_10083_10561_10312_10313_10314_10550_10073_10551_10552_10553_10554_10557_5650011,searchweb201603_30,ppcSwitch_5&btsid=60d39259-cffc-47f1-8580-583c22469895&algo_expid=8ffdf214-4db8-41c0-b806-73d0a39ffc54-12&algo_pvid=8ffdf214-4db8-41c0-b806-73d0a39ffc54
https://www.aliexpress.com/item/New-32-PCS-Finether-Socket-Screwdriver-Set-Multifunction-Hand-Tools-Mini-tool-Sets-For-drones-small/32840987820.html?spm=2114.search0104.3.92.3iQWKj&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10344_10345_10342_10343_10340_10341_10543_10541_10307_10301_10060_10155_10154_10056_10055_10539_10537_10536_10059_10534_10533_100031_10103_10102_5670011_10169_10142_10107_5660011_10562_5740011_10084_10083_10561_10312_10313_10314_10550_10073_10551_10552_10553_10554_10557_5650011,searchweb201603_30,ppcSwitch_5&btsid=60d39259-cffc-47f1-8580-583c22469895&algo_expid=8ffdf214-4db8-41c0-b806-73d0a39ffc54-13&algo_pvid=8ffdf214-4db8-41c0-b806-73d0a39ffc54
1 час назад, 2xded сказал:
По Вашим ссылкам "К сожалению, этот товар теперь недоступен!". Посты набиваете?:angry:
Зря вы так - я только что (час назад) купил один наборчик домой
Посмотрел хотел купить, пока ходил по делам уже товар не доступен)))
Нет был доступен!
solid молодец!!!
10 часов назад, 2xded сказал:
Ничего не набивает, даже заказать успел, посмотрим чем дело кончиться.
Соглашусь с коллегами, тоже успел заказать наборчики и не один. Такие вещи по такой смешной цене раскупаются как горячие пирожки. Спасибо за ссылку solid
23 часа назад, 2xded сказал:
просто все кинулись покупать .. я тоже заказал 2 набора ..)))
Иногда приходит, иногда нет.
Отвертки должны прийти, а это вряд ли, но вдруг:dada:
9 минут назад, Winzor сказал:
ошибается
в данном случае.
Рейтинг просмотров 100 проц.,у Али своя система.
Что получается продавец просто не отправит заказ и все?? Или все таки раз продал будет обязан?
18 минут назад, vyugovp сказал:
Диаг инструмент: дорогой,система, проблема,мы должны были регулировать цены,может вы PLS отменить заказ,выбрать причину вам не нужно больше,мы будем полный возврат,спасибо - продаван уже просит)))
11 минут назад, vyugovp сказал:
ага .. что делать??? а если я не откажусь??
Если продавец товар не отправил - заказ автоматически отменится и деньги через некоторое время вернутся вам на счет, с которого платили.
24 минуты назад, vyugovp сказал:
Я попросил wifi elm327 взамен
