Vitas777 217 Опубликовано 19 февраля, 2020 Поделиться Опубликовано 19 февраля, 2020 Требуется помощь клуба. VW Caravelle 2017 2.0 TDI CXGA 62kw vin: WV2ZZZ7хххххххххх. Есть система СТАРТ-СТОП. ABS 7E0 907 379P H06 0133 Авто после ДТП, АБС обесточен. После восстановления имеем кодировку блока АБС 0000000000000000000000000000. Нарыл следующую инфу: T6 ABS coding: Green = Changes possible / Red = vehicle configuration / Blue = VIN serialByte 0 Chassis type T6 = 30, 34, 51, 55, 65 etc / Caddy = 10 Byte 1 Chassis type T6 = 7E / Caddy = 79 Byte 2 Drive train 2WD = 40 / 4WD = 80 Byte 3 Chassis type (as byte 1) 7E = 98 / 79 = 9B Byte 4 Chassis type 25, 65 = T6 4WD / 92 = Caddy 2WD, 93 = Caddy 2WD LHD, B3 = Caddy 4WDByte 5 VIN serial # 13 0 = 62, 1 = 63, 2 = 64, 3 = 65, 4 = 66, 5 = 67, 6 = 68, 7 = 69, 8 = 6A, 9 = 6BByte 6 Configuration 84 = Hill start assist UG1 / 86 = Hill descent control UG5 - Note: Change byte 6 and 14 togetherByte 7 VIN serial # 14 0 = 7E, 1 = 7F, 2 = 80, 3 = 81, 4 = 82, 5 = 83, 6 = 84, 7 = 85, 8 = 86, 9 = 87Byte 8 Chassis type (as byte 0) 34 = 2C, 30 = 0C, 51 = 8A, 55 = AA, 65 = 86 etcByte 9 VIN serial # 15 0 = 75, 1 = 76, 2 = 77, 3 = 78, 4 = 79, 5 = 7A, 6 = 7B, 7 = 7C, 8 = 7D, 9 = 7EByte 10 Drive train type 01 = 4WD / 02 = 2WDByte 11 VIN serial # 16 0 = 76, 1 = 77, 2 = 78, 3 = 79, 4 = 7A, 5 = 7B, 6 = 7C, 7 = 7D, 8 = 7E, 9 = 7FByte 12 Chassis type (as byte 4) A6 = T6 4WD, A4 = T6 2WD / C9 = Caddy 2WD, CD = Caddy 4WD, 49 = Caddy 2WD LHDByte 13 VIN serial # 17 0= 82, 1 = 83, 2 = 84, 3 = 85, 4 = 86, 5 = 87, 6 = 88, 7 = 89, 8 = 8A, 9 = 8BByte 14 Chassis type (as byte 6) 84= 21 (Hill start assist UG1) / 86 = 61 (Hill descent control UG5) - Note: Change byte 6 and 14 together Byte 15 Configuration A6 = Without TPM / D3 = With TPM 7K9Byte 16 Engine 38 = CAAC+LHD, 39=CAAC+RHD, 78 = CXHA, CXEB, CXFA, CUUD, DFSB+LHD, 29 = CAYD, CAYE+RHD, 28 = CAYD+LHD Byte 17 ACC/City brake 00 = No ACC, F5, F7 = T6 ACC / F1, F7 = Caddy ACC По кодировкам остался вопрос по 0 и соответственно 8 байтам, а так же по 16 байту (CXGA в списке отсутствует) По ней восстановил вариант кодировки 30 7E 40 98 25 6A 84 85 0C 7B 02 7A A4 8A 21 D3 38 00 00, который блок проглотил (вопрос по 0, 8 и 16 байтам открыт). Кодировка принята, ошибки отсутствуют. На панели горят АБС и ЕСП. Тестовая поездка с вращение рулем не помогла. Адаптация датчика угла поворота руля через 03 блок не проходит (не соблюдены условия или порядок), через 04 блок требует логин (40168 не принимает). 04 блок 6R0 959 654 H07 0070 Какой логин в 04 блок и каков порядок адаптации? Буду рад любой инфе или совету. Ссылка на комментарий Поделиться на другие сайты Поделиться
Roma 158 Опубликовано 19 февраля, 2020 Поделиться Опубликовано 19 февраля, 2020 ODIS -Engeniring Ссылка на комментарий Поделиться на другие сайты Поделиться
Vitas777 217 Опубликовано 3 августа, 2020 Автор Поделиться Опубликовано 3 августа, 2020 С авто разобрался, кодировку восстановил. Ссылка на комментарий Поделиться на другие сайты Поделиться
