Igorian 41 Опубликовано 21 июня, 2018 Автор Поделиться Опубликовано 21 июня, 2018 12 минут назад, kvvweb сказал: ну типа такого v.178.0.8 + патч https://drive.google.com/file/d/1eOgUZJYMv4F8PAs29o60ysJZ7Zy7xcY7/view?usp=sharing А что за патч? Ссылка на комментарий Поделиться на другие сайты Поделиться
kvvweb 237 Опубликовано 21 июня, 2018 Поделиться Опубликовано 21 июня, 2018 9 минут назад, Igorian сказал: А что за патч? для взлома реестра. 1st replace the original RSWin.exe file (backup 1st your original file!!!) with the Cracked .exe file in C:\CLIP_X91\Lib\Application\ 2. Now from the SAME location as you are (C:\CLIP_X91\Lib\Application\) run the RSWin.exe, choose "Register me now" and in the next window select "NO"! 3. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF It will work till 31/12/2020 4. Now as you are, RESTORE your original RSWin.exe and REMOVE the patched one! (Just keep a backup from the patched file somewhere...) 5. From your Desktop anymore, run your CLiP, accept the Terms and CLiP it will load. You Done! SPECIAL NOTES: Maybe when you try to make your 1st REAL Diagnosis you received an "Error" (about CLiP Damaged...) try to Update your PC with ALL the Latest Windows Updates! IF again the SAME "Error" then use 1x other PC or Roll-Back to Version V116! CLiP it seems, she no likes some PC's! Also when you will make your Registration, try to have your PC On-Line to the Internet! IF you NOT able to use 1x other PC and you insist to use this Latest Release, then you can post your S/N and you will got your personal Registartion Key. For this workaround you will need to use your ORIGINAL RSRWin.exe and also 1st of all to DELETE these 2x files: "reg.xml" & "ntuser.dat" from your: C:\Documents and Settings\All Users (Windows XP) C:\ProgramData (Windows 7 32Bit) NOTE: BEFORE to delete your reg.xml file, open it & note somewhere your COMPLETE S/N! Enjoy & Good Clipping! Ссылка на комментарий Поделиться на другие сайты Поделиться
Igorian 41 Опубликовано 21 июня, 2018 Автор Поделиться Опубликовано 21 июня, 2018 Ух, какое все древнее и сложное))) Давно таким способом не пользовался. Для активации CLiP уже года 4 в инете гуляет кальк, в котором указываешь любую дату окончания активации и он калькулирует ключ регистрации))), а не как в этом способе, до 21-го года. VADIK-VOLT 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
Serhii621 63 Опубликовано 5 июня, 2019 Поделиться Опубликовано 5 июня, 2019 Пани поделитесь пожалуйста ссылочкой на программу Can clip Ссылка на комментарий Поделиться на другие сайты Поделиться
