Multi Ecu Scan
Do you have crack for it?
Great! Upload
I upload MultiEcuScan 2.2 with crack/loader.
http://rghost.net/7DLHsBqjh
See the TXT for istruction.
If you are connect to internet the program non work.
Repeat the installation for fix it.
I use it for a long time.
I use it mainly with a kit bluetooth ELM327 OBD.
For access to all modules the KIT do not have a resistor for CAN+ and CAN-.
Remove this resistor and work OK to all modules (abs....instruments...ecc).
Tomorrow i send istruction for modding the ELM327 blueooth kit.
Good! Hide link to txt file and atach it to post. That only registered users can download it.
Just, press Изменить in the bottom right  corner of your post.
