ECU Toyota Gen 1 K-Line bricked recovery.
Hello guys!
I have a problem, i have a toyota 1kd engien ecu hw: 89661-0k400 and board nº: 175822-666. Problem is that i read with ktag and write a couple times via jtag, and last time i wrote other file to test and ecu now i have communication, but car not start, and when im trying to read again with ktag or upload recovery ktag says: "Non compliant plugin". Anyone have any idea of how can recover it or write other file again with ktag? I also try to write a correct file with pcm flash and no success.
Thanks in advance.
20 минут назад, Valen1233 сказал:
Hello guys!
Thanks in advance.
Your ecu may have died. Buy another ecu, and transfer the eeprom data, and you will be successful.
выложите сюда то что считано с блока возможно не правильно считан как вариант пролить другой фулл и проверить
