Volvo xc60 2020 ASDM u111600 RML
Хз как в 60, в 90 в полу под сидением.
Description
The Restraint Module Left (RML) consists of an electrical motor and a control unit. The seat belt in the front left seat is equipped with a Restraint Module Left (RML). The Restraint Module Left (RML) purpose is to position the occupant in the front left seat in the correct position in a pre-crash situation. The Restraint Module Left (RML) applies tension on the seat belt when activated. The Restraint Module Left (RML) has a reverse functionality that can be used a limited number of times. When the maximum number of times is used, the Driver Information Display (DIM) shows a service message in the combined instrument display.
Всем большое спасибо . Я думал это система дистроника.так как не работает дистроник а ошибок в блоке подушек безопасности нет.
