renault ems 3125 need help
rinaprasant
hello
i have renualt duster patrol ems 3125
i have one working car & 5 car all with ecu lost
i buy 5 pis from market
now with flex working car i read password & via obd flash map & make immo off & check ecu perfect car start
but now i try with another car flex 17 not connected via obd may bcoz immo active
if nay one help me on that
in my mind if all set okk than uch may some oprate any other rely & more 12 v on ecu socket
https://carlabimmo.com/manuals/immob...h-can-ver3.pdf
bcoz i saw this documents
if nay one help or i have pcm flash if that nodule can read than i active
thanks
Hi. When immo active you can't do anything via OBD.
but i try with boot but that need password
is any software make coding or flash ?
thanks
Only one software in the world can do clone of this ECU. Combiloader. If you don't have it forget about clone!
thanks
but for coding this block ?
all car only ecu lost , all have same part number ecu
renolink or any software can make coding with uch possible
thanks
hello
Combiloader. & pcm flash both different ?
i have pcm flash dongle , abrites , autel , x17
thanks
3 часа назад, rinaprasant сказал:
thanks
thanks
Renolink or any software can pair only virgin ECU. For do virgin need read flash+eeprom, make some changes and write it back. Or buy absolute new ECU, reprog it with clip and pair using renolink or another tool.
44 минуты назад, rinaprasant сказал:
hello
thanks
Combiloader is not the same PCMFlash.
thanks
