opel zafira 1.8 2002
GO111LD
zdrastvite u menia est zafira a 1.8 2002,    B3059  Present ( 0 )  No Engine Request Received
                                                             B3040  Present ( 0 )  Communication Malfunction on W-line    pomagite pojalusta...
Смотри здесь http://carmasters.org/topic/11806-opel-astra-g-2001г-p3059/
Выдержки из тис 2000
B-01  DIAGNOSTIC TROUBLE CODE     B3059  No Engine Request Received
After ignition ON, no request signal from the engine control unit has been recognised
Concerned Terminals: 2
B-01  DIAGNOSTIC TROUBLE CODE    B3040   Communication Malfunction on W-line
During communication between engine and immobiliser control unit transmission was interrupted.
Concerned Terminals: 7
  • 2 недели спустя...
hello friend, sorry for my english, i have opel zafira 1.8 2002, i changed ecu, no immo, immo is old, i want program old immo to new ecu, i have opcom, i need security code please helps me, old ecu is dead... vin code is: W0L0TGF7522160481
3 часа назад, GO111LD сказал:
hi friend first you need renew ecu because personalization ecu and immo
to do  renew  you need  security code.  it can be read from ecu or  immo
but for this it is necessary  other equipment.
В 23.07.2018 в 23:12, GO111LD сказал:
ecm 5b686d1f5d02b_immo2copy.jpg.fb0d201009f70d3e42c8040def3402ad.jpgECM SYNC= W-line
  • Последние посетители   1 пользователь онлайн
