Airbag Punto EVO 2011 MJT1.3 Continental 51918197 A2C53440429
Hello everyone, I come back to the subject for help to restore the airbag red light of the Punto Evo. A few months ago the airbag control unit stopped working and I bought a used ECU with the same codes, I proceeded to recover the eprom file 95320 with the UPA programmer, I reprogrammed the eprom, I connected the control unit in the Punto, it worked for about two hours and only the red light that indicates the failure of the Airbag unit reappears, only aibag passenger and belts remain working, I connect with Multiecuscan and gives me error B0100 - B0109 - B0108 and B1052, all the configuration parameters seem OK in the sense that the resistances are from 2.5 to 3.0 ohms. I note that the old control unit stopped working suddenly without an accident. How can I solve the problem? Thanks for your help
В 01.07.2018 в 22:29, abbate22 сказал:
you must to, repair all damaget parts , make diagnostic, and put the reset module in the car, (sand me the crach dump)
resistances are from 2.5ohm is good
On 2/7/2018 at 22:35, inri said:
è necessario, riparare tutte le parti danneggiate, fare diagnosi e mettere il modulo di reset in macchina, (sabbiare la discarica del crach) le
resistenze sono da 2.5 ohm è buono
Thanks for the reply. The parts look good, I add the photos of the diagnosis and the original eprom file.
Eprom 95320 airbag originale.bin
