bmw74alex 54 Опубликовано 31 января, 2017 Поделиться Опубликовано 31 января, 2017 MAGPro2 X17 ver 10.60.00 released Here we are with the first update of the year! This time we are bringing you even more magic protocols – we are now focusing on VAG DELPHI: the DCM6.2V is now available by OBD (1.4 TDI, 1.6 TDI, 2.0 TDI and 2.0 BiTDI engines from 2013 on) along with the DCM3.7 (1.2 TDI engines). Let’s have an in depth look at the DCM6.2V: this ECU is really interesting, because it is used in so many types of vehicles that it is easily accessible to any type of repair garage or chiptuner: VW Crafter; VW Caravelle, Multivan, California & Transporter T6; VW Golf, Audi A3, Seat Leon and Skoda Octavia; VW Polo, Audi A1, Seat Ibiza and Skoda Fabia. This means that being able to work on this unit – especially since they have been around for quite some time – will deeply expand your business possibilities. Furthermore, all our customers will finally be able to work on PSA (and FIAT) SIEMENS SID208! This new solution will only be available to you if you send the ECU to our main HQ in Italy. Our Team will send you back your ECU and BL password in 24h and you will be able to read and write it in bootloader mode. +150 vehicles have been added in this release. New protocols added: AUDI DELPHI DCM6.2V: OBD UDS R/W/CHK/RECOVERY CITROEN BOSCH MEG17.9.52 TC1782: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/RECOVERY, PASS READ by MAGP1.18 CITROEN SIEMENS SID208 TC1797: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/RECOVERY, PASS READ* FIAT BOSCH ME17.9.51 TC1762/1766: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/RECOVERY FIAT SIEMENS SID208 TC1797: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/RECOVERY, PASS READ* MERCEDES DELPHI CRD3.x TC1793: BL IROM R/W/CHK/RECOVERY PEUGEOT BOSCH MEG17.9.52 TC1782: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/CHK/RECOVERY, PASS READ by MAGP1.18 PEUGEOT SIEMENS SID208 TC1797: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/RECOVERY, PASS READ* _________!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SEAT DELPHI DCM3.7: OBD UDS R/W/CHK/RECOVERY SEAT DELPHI DCM6.2V: OBD UDS R/W/CHK/RECOVERY SKODA DELPHI DCM3.7: OBD UDS R/W/CHK/RECOVERY SKODA DELPHI DCM6.2V: OBD UDS R/W/CHK/RECOVERY SUZUKI BOSCH ME17.9.51 TC1762/1766: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/RECOVERY TOYOTA BOSCH MEG17.9.52 TC1782: BL IROM R/W/CHK/RECOVERY, BL EEPROM R/W/CHK/RECOVERY, PASS READ by MAGP1.18 VW DELPHI DCM3.7: OBD UDS R/W/CHK/RECOVERY VW DELPHI DCM6.2V: OBD UDS R/W/CHK/RECOVERY У кого есть MAGPro2 X17 ver 10.60.00 ? Ссылка на комментарий Поделиться на другие сайты Поделиться
abracadabra 301 Опубликовано 31 января, 2017 Поделиться Опубликовано 31 января, 2017 Ну да... только сначало им надо свой сид208 псашный отослать, они там что то ломанут и перешлют тебе его взад, вот может тогда и заработает, интересно, кто нибудь отсылал им блок? Ссылка на комментарий Поделиться на другие сайты Поделиться
Makson4eg 31 Опубликовано 26 марта, 2017 Поделиться Опубликовано 26 марта, 2017 Вот нафига лягушатники так закрыли этот блок, уроды одним словом. Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 26 марта, 2017 Автор Поделиться Опубликовано 26 марта, 2017 да и без них этот кроссворд решается. Лишь бы проц живой остался Ссылка на комментарий Поделиться на другие сайты Поделиться
Makson4eg 31 Опубликовано 26 марта, 2017 Поделиться Опубликовано 26 марта, 2017 Ну поведай нам Ссылка на комментарий Поделиться на другие сайты Поделиться
abracadabra 301 Опубликовано 26 марта, 2017 Поделиться Опубликовано 26 марта, 2017 Я думаю, что это решается на уровне замены трикора... Впринципе если снять лог с кан шины при телезагрузке с сервака PSA, разобрать его, и если еще будут данные не криптованы... Но когда этим всем заниматся? Убьешь хер знает сколько время и нервов... bmw74alex 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
Makson4eg 31 Опубликовано 26 марта, 2017 Поделиться Опубликовано 26 марта, 2017 Зареболить свой не закрытый трикор? Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 27 марта, 2017 Автор Поделиться Опубликовано 27 марта, 2017 Это самое простое. Переставляешь живой чип на донора и ехай Ссылка на комментарий Поделиться на другие сайты Поделиться
chipauto 1 155 Опубликовано 27 марта, 2017 Поделиться Опубликовано 27 марта, 2017 В 31.01.2017 в 14:47, abracadabra сказал: Ну да... только сначало им надо свой сид208 псашный отослать, они там что то ломанут и перешлют тебе его взад, вот может тогда и заработает, интересно, кто нибудь отсылал им блок? отсылали 2 шт abracadabra 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
abracadabra 301 Опубликовано 27 марта, 2017 Поделиться Опубликовано 27 марта, 2017 22 часа назад, Makson4eg сказал: Зареболить свой не закрытый трикор? А хрен с него с пустого толку? Вот если флешем и епромом разжиться, тогда будет толк с перестановкой "пустого" Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 27 марта, 2017 Автор Поделиться Опубликовано 27 марта, 2017 8 часов назад, chipauto сказал: отсылали 2 шт Вернулись ? 21 минуту назад, abracadabra сказал: А хрен с него с пустого толку? Вот если флешем и епромом разжиться, тогда будет толк с перестановкой "пустого" А чем лить будешь флешь ? Хоть бы пока загрузчиком разжиться. Ссылка на комментарий Поделиться на другие сайты Поделиться
abracadabra 301 Опубликовано 28 марта, 2017 Поделиться Опубликовано 28 марта, 2017 В пустой трикор дамп залить вообще не проблема, штатное средство от инфинеона, если не запаролен доступ к памяти, инфинеон мем тул обзывается bmw74alex 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 16 мая, 2017 Автор Поделиться Опубликовано 16 мая, 2017 Сам пробовал ? у меня пяток блоков лежит с чистым процем , могу продать Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 24 мая, 2017 Автор Поделиться Опубликовано 24 мая, 2017 We improved our PSA & Fiat SID208 solutions: now it is possible to read calibration zone and EEPROM directly by OBD! Итальяхи уже допилили. SID 208 PSA -можно писать . читать через ОБД Ждем китайских коммунистических товарищей. abracadabra 1 Ссылка на комментарий Поделиться на другие сайты Поделиться
autoatis 10 Опубликовано 12 июня, 2017 Поделиться Опубликовано 12 июня, 2017 http://msauto.lviv.ua/psa-sid-208/ Вот эти ребята заявляют, что делали уже неоднократно ПСА СИД208. При чем по ОБД. Я им звонил по телефону. Чем работают, не рассказывают. Я так понимаю, что MAGPro. Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 12 июня, 2017 Автор Поделиться Опубликовано 12 июня, 2017 Ещё одна контора сделала программатор по ОБД Ждём китайцев Ссылка на комментарий Поделиться на другие сайты Поделиться
autoatis 10 Опубликовано 12 июня, 2017 Поделиться Опубликовано 12 июня, 2017 Ну вроде китайцы что-то предлагают. http://www.dhgate.com/store/product/cartuning-1pc-magpro2-chiptuning-tool-mag/378081786.html https://ru.aliexpress.com/store/product/OBD2Tuning-Magpro2-chiptuning-tool-Mag-pro-2-v4-2/205320_1433809644.html?src=google&albch=search&acnt=479-062-3723&isdl=y&aff_short_key=UneMJZVf&albcp=266121556&albag=7593673036&slnk=&trgt=dsa-42862830006&plac=&crea=64152518716&netw=g&device=c&mtctp=b&memo1=1t1&gclid=CKKQ3sOFuNQCFVOMGQodHccFiw Ссылка на комментарий Поделиться на другие сайты Поделиться
chipauto 1 155 Опубликовано 12 июня, 2017 Поделиться Опубликовано 12 июня, 2017 это древнейшая как мамонт версия магпро откурит она Ссылка на комментарий Поделиться на другие сайты Поделиться
autoatis 10 Опубликовано 12 июня, 2017 Поделиться Опубликовано 12 июня, 2017 Может есть у кого-то в Киеве или поблизости MAGPRO официальный? Отзовитесь. Можем сотрудничать. Французы едут, а делать нечем. У меня оф. Ктаг, ради сид208 не хочется покупать. Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 12 июня, 2017 Автор Поделиться Опубликовано 12 июня, 2017 Надо версию выше 10 ловить Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 25 октября, 2017 Автор Поделиться Опубликовано 25 октября, 2017 Произошли следующие изменения в Загрузчике прошивок PCMflash Добавлен новый Модуль 60 Citroen/Peugeot (PSA) SID208 предназначенный для работы с ЭБУ SID208, устанавливаемый на а/м с дизельным двигателем 2.2л. Поддерживается чтение, запись, раpблокировка ЭБУ для записи модифицированных прошивок, а также проверка и коррекция контрольных сумм. (скидка для владельцев Модуля 53) Citroen/Peugeot 2.2L HDi (SID208) [WR/CK] (запись после разблокировки в BSL) Citroen/Peugeot 2.2L HDi (SID208/BSL) [UNLOCK/RD] В Загрузчик прошивок CombiLoader добавлены модули: Delphi MT86 Hyundai/Kia EMS3155 Renault SID208 PSA Ссылка на комментарий Поделиться на другие сайты Поделиться
autochipkmua 161 Опубликовано 25 октября, 2017 Поделиться Опубликовано 25 октября, 2017 В 12.06.2017 в 15:04, autoatis сказал: Может есть у кого-то в Киеве или поблизости MAGPRO официальный? Отзовитесь. Можем сотрудничать. Французы едут, а делать нечем. У меня оф. Ктаг, ради сид208 не хочется покупать. есть magpro стучи если что делаем без проблем Ссылка на комментарий Поделиться на другие сайты Поделиться
Spiria 8 Опубликовано 18 ноября, 2017 Поделиться Опубликовано 18 ноября, 2017 зачем вы трупняк разворошили??? Ссылка на комментарий Поделиться на другие сайты Поделиться
bmw74alex 54 Опубликовано 19 ноября, 2017 Автор Поделиться Опубликовано 19 ноября, 2017 Не по теме умняк Ссылка на комментарий Поделиться на другие сайты Поделиться
autoatis 10 Опубликовано 19 ноября, 2017 Поделиться Опубликовано 19 ноября, 2017 Уже раскрыли данный ЭБУ. Теперь все будут делать. И еще Alientech добавил к себе. КТаг теперь его по диагностике может делать. Ссылка на комментарий Поделиться на другие сайты Поделиться
