Jump to content
Важное изменение в правилах форума!!! Обязательно к ознакомлению: http://carmasters.org/topic/20603-поправка-к-правилам-форума-№1-всем-ознакомиться-в-обязательном-порядке/
limard_
замена эбу на А8 кузов 1999 год 3.7 мотор
Recommended Posts
чем сделать адаптацию ?
получится ли сделать замену блока ?
или можно просто дамп перелить фулл и готово ?!
Share this post
Link to post
Share on other sites
ECM Matching
Prerequisites:
Battery voltage at least 12.5 V.
Immobilizer II ECM
[Select]
[17 - Instruments]
[Adaption - 10]
Leave channel at "00"
[Read]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
[Exit]
Turn ignition OFF for 15 seconds. Start vehicle.
Notes:
For cars with a separate Immobilizer (Includes 2000+ EuroVan, Cabrio, and many older non-US models), use [25 Immobilizer] instead of [17 - Instruments]. The rest of the procedure is the same.
On some Euro Audi models with Immobilizer 2, the PIN/SKC will be required.
On NAR market Cabrio models produced after 05/1999 the PIN/SKC may be required. This split is noted here
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_II_ECU_Swapping
Share this post
Link to post
Спасибо , вопрос закрыт !
Share this post
Link to post
Guest
This topic is now closed to further replies.
  • Recently Browsing   0 members
    No registered users viewing this page.
