fantomel 576 Опубликовано 1 октября, 2015 Поделиться Опубликовано 1 октября, 2015 Actia Multi-Di @ g MDO 2014.2 SP1 VMWARE for Serial 093479 China 2011 This is a Virtual Machine a little more special, so please be careful and read the lines. I will not explain more then it's already written. 1.This virtual machine works only if you have an Intel processor that supports virtualisation, this means Intel processors Ix from second generation UP (4 numbers in model) not older. 2.This virtual machine it's frozen to the current state so this means that after any power off all that you leave inside will be gone but you have means to get files out from it while it's working (see READ.txt) 3.This virtual machine works only with interfaces that have serial number 093479 also known as china clones VCI1 2011. 4.I recommend to use it with VMWare Player 6.0.x or Wmware Workstation 10.0.x. (VM is compatible Workstation 9) 5.Extract archive to desired folder, double click on MDO2014.vmx and when you open the virtual machine for the first time click "i moved it" Inside VIrtual Machine i left documentation, a pdf reader and a pdf printer to help you get diagnostic reports out of it to real pc. Also inside this VM is a watermark so like this it can not be sold over internet as many good stuff are. This vm been Has tested and retested by me and friends, I have no problems at all and was made just for fun and of course for FREE. Enjoy. PS The pic dump for this serial number is free in my collecton or here in download link with tutorial also if your interface has another serial. If you receive an error while you open this VM it means that you processor it's not supported so do not bother to ask why this and that, simple answer is it's too old. 2014.2Archive Password: fantomel4freemdo2014Open VM Password: 6666Multi-Di@g MDO 2014.2 SP1 VMWARE for Serial 093479.txt Ссылка на комментарий Поделиться на другие сайты Поделиться
