Rodrigo 0 Опубликовано 12 мая Поделиться Опубликовано 12 мая Chasing saves in MLB The Show 26 can feel silly at first, especially when you've done most things right and the box score still says nothing. Maybe you're working through a program, maybe you're saving bullpen arms, or maybe you're just trying to stack stats while building up MLB stubs for your next upgrade. Either way, the game isn't judging effort. It's judging the exact situation when your reliever comes in. The cleanest setup is simple: take a lead of three runs or fewer into the last inning, bring in a relief pitcher, and let him finish it. Up 3-1? Great. Up 5-2? Still fine. Up 7-3 because you got greedy in the eighth? That's where players usually mess it up [url=https://www.u4gm.com/mlb-the-show-26/stubs]MLB The Show 26 stubs[/url]. Keep the lead close The normal save chance is built around pressure. Your reliever needs to protect a small lead, not just throw a few pitches in a game that's already over. So if you're farming saves, don't treat every at-bat like a home run derby. I know, it's hard to stop swinging when the CPU is hanging sliders. But if you stretch the lead past three runs before the ninth, that easy save setup can disappear. A good habit is to slow down late in the game. Take singles, move runners, or even let an inning end if the mission matters more than padding the score. The odd save situations still count There are exceptions, and they're the reason this rule confuses so many players. A reliever can qualify for a save with a bigger lead if the tying run is close enough to matter when he enters. For example, a four-run lead with the bases loaded creates a save spot because the batter at the plate can bring the tying run around. A five-run lead can also work if the tying run is on deck. It's real baseball logic, and the game follows it pretty well. Still, it's not something I'd plan around unless the game hands it to you. Loading the bases on purpose just to force a save chance is asking for trouble. The three-inning trick The rule most players forget is the long save. If a relief pitcher throws the final three innings of a win, he can earn a save no matter how large the lead is. This is perfect when you're up big and don't want to burn your closer. Bring in a fresh arm in the seventh, pitch the seventh, eighth, and ninth, and make sure he records the last out. Don't swap him out because one hitter reached base. Don't bring in your favourite closer for one dramatic pitch. The pitcher who finishes the game is the one who gets the credit, and if he leaves early, the save usually leaves with him. Don't overmanage the last few outs Most missed saves come from tiny choices, not bad gameplay. Players change pitchers mid-inning, pile on too many runs, or forget that a starter can't usually be used like a closer for this stat. If you're trying to clear missions fast, treat the save like a setup job. Build the right score, choose one reliever, and ride it out unless the game is falling apart. It's the same kind of practical planning people look for when searching for the fastest way to get stubs in MLB The Show 26, because wasted games add up quickly [url=https://www.u4gm.com/mlb-the-show-26/stubs]MLB The Show 26 stubs for sale[/url]. Watch the lead, trust your pitcher, and let the final out do the work. Ссылка на комментарий Поделиться на другие сайты Поделиться
