sergeykr 46 Опубликовано 27 июля, 2015 Поделиться Опубликовано 27 июля, 2015 Привет всем. Авто Jeep Liberty 2007 г. Мкпп дв. 2,4 л. 170 л.с внезапно пропало управление стартером. На прямую , на втягивающее все крутит, с ключа тишина. Нужна помощь, пните в нужную сторону, спасибо Ссылка на комментарий Поделиться на другие сайты Поделиться
FootM 136 Опубликовано 28 июля, 2015 Поделиться Опубликовано 28 июля, 2015 Была недавно такая.При МКПП смотреть концевик сцепления.Вот от дилеров. Ignition Switch² Visually inspect ignition switch for indications of physical damage and loose or corroded wire harness connections.Clean corroded connections as required. Refer to Wiring Diagrams. Refer to Ignition Switch and KeyLock Cylinder for ignition switch service procedures.8F - 52 STARTING SYSTEM KJClutch Pedal Position Switch² If vehicle is equipped with a manual transmission, visually inspect clutch pedal position switch for indications ofphysical damage and loose or corroded wire harness connections. Clean corroded connections as required.Refer to Clutch Hydraulic Linkage for clutch pedal position switch service procedures.Park/Neutral Position Switch² If vehicle is equipped with an automatic transmission, visually inspect park/neutral position switch for indicationsof physical damage and loose or corroded wire harness connections. Clean corroded connections asrequired. Refer to Park/Neutral Position Switch for park/neutral position switch service procedures.Starter Relay² Visually inspect starter relay for indications of physical damage and loose or corroded wire harness connections.Clean corroded connections as required. Refer to Starter Relay for starter relay service procedures.Starter Motor² Visually inspect starter motor for indications of physical damage and loose or corroded wire harness connections.Clean corroded connections as required. If problem being diagnosed involves improper starter engagement,disengagement or noise complaints, starter motor should be removed. With starter motor removed,inspect starter pinion and ring gears for damaged or missing teeth. Replace faulty components as required.Refer to Starter Motor for removal/installation procedures.Starter Solenoid² Visually inspect starter solenoid for indications of physical damage and loose or corroded wire harness connections.Clean corroded connections as required. Refer to Starter Motor for starter solenoid service procedures.Wiring² Visually inspect starting system wire harnesses for indications of physical damage. Repair or replace any faultywiring, as required. Refer to Wiring Diagrams for repair or connector and terminal service procedures. во вложении страница 2150Jeep Liberty KJ FSM 2006.rar Ссылка на комментарий Поделиться на другие сайты Поделиться
sergeykr 46 Опубликовано 28 июля, 2015 Автор Поделиться Опубликовано 28 июля, 2015 спасибо за ответ, но концевик проверили, в норме. при нажатии замыкается на коротко Ссылка на комментарий Поделиться на другие сайты Поделиться
