Need checksum fix asap
Cgraenge
Hello, can someone please help me fix checksum error on NGC3, premapped ecu - for dodge ram.
i made DTC off with SVEDIT, but it makes checksum error, starts 1st time and won’t start after.
Hi, send the file here or to my email, I'll fix it now.
Files is uploaded to my Dropbox here: https://www.dropbox.com/scl/fo/y8t6anqnz2z40xq8fbaqf/AIkmVKlkDfKJi1UJpgwsvYk?rlkey=3vdjzs4c08na069umur7ioom0&st=yp6ehpa6&dl=0
please let me know if there’s any problems with link or anything
thank you!!
Ori read file, and DTC OFF file (the one I need fixed)
SVEDIT_DTC OFF_NGC3_boot_udlæs.bin NGC3_boot_udlæs.mpc
The file that was made is crooked.
The original file opens winols without problems. Your firmware, where the errors are disabled, has errors.
Yes, and I need to flash the ecu with the DTC-OFF file.
can you fix the errors?
These are the fault codes I’m trying to disable: P0585
P0593
P0733
P1790
P0562
5 минут назад, Cgraenge сказал:
P0593
P0733
P1790
P0562
WinOLS_NGC3_DTC_off_cs_ok.bin
If anyone else can help, please write.
its very urgent 🚨
car still wont start, only first time and shuts off.
i really hope someone can help me disable the error codes, and corrigate checksum.
