renolink ems3125 coding help
rinaprasant
hello
i have renolink 1.98
need help for ems3125 vergin ecu i have
but how to code with renolink pl help me
i try with UCH with xml file 'after sales paring ecu "
but need after sales 16 digit code
or how ro anu one help me
thanks
hello
i have one car with 0 error & this car ecu i made immo off with magic read password obd
i have 5 car with ecu lost
one member help me & told me for buy combiloader i try but russai paypal not accept so difficuilt to buy , i still try ...........
i have 5 new ecu but may this ecu have no data blank
bcoz today i just information with renolink scan
below attach picture of screen shot renolink
thanks
hello
my job done with below trick but still need some help
i have one working car
so with magic x17 connect via OBD , password read & save , than read map & save
so after that read/ write map options highlight
after that change new blank ecu & write above map 2560km
check light came on
than in renolink options KEY/RENULT UCH4 ECU LEARN / all success
car start but after ignition on / off not start
so agian do ecu learn & with xml file options / after sales ecu paring with 16 dighit pin
than do vin write
than with launch online confugration data transfer send ok
than car start perfect
but all do with my working car BCM / KEY so my another set need to BCM VERGIN & code
but in this process i not success & i try
but ECU CODING SUCCESS
thanks all of u for help
hello
my 4 duster ph2 patrol done
thanks to all fo you
but now 2 captur with HFM module with jonshon control spc5605 mcu
but if i try with renolink , when pin red no data message & if i try with UCH T4 than erpprom need to unlock please unable it , is any one help me
thanks
topic closed
