rinaprasant 257 Опубликовано 16 апреля, 2022 Поделиться Опубликовано 16 апреля, 2022 hello i have renolink 1.98 need help for ems3125 vergin ecu i have but how to code with renolink pl help me i try with UCH with xml file 'after sales paring ecu " but need after sales 16 digit code or how ro anu one help me thanks Ссылка на комментарий Поделиться на другие сайты Поделиться
rinaprasant 257 Опубликовано 17 апреля, 2022 Автор Поделиться Опубликовано 17 апреля, 2022 hello i have one car with 0 error & this car ecu i made immo off with magic read password obd i have 5 car with ecu lost one member help me & told me for buy combiloader i try but russai paypal not accept so difficuilt to buy , i still try ........... i have 5 new ecu but may this ecu have no data blank bcoz today i just information with renolink scan below attach picture of screen shot renolink thanks Ссылка на комментарий Поделиться на другие сайты Поделиться
rinaprasant 257 Опубликовано 19 апреля, 2022 Автор Поделиться Опубликовано 19 апреля, 2022 hello my job done with below trick but still need some help i have one working car so with magic x17 connect via OBD , password read & save , than read map & save so after that read/ write map options highlight after that change new blank ecu & write above map 2560km check light came on than in renolink options KEY/RENULT UCH4 ECU LEARN / all success car start but after ignition on / off not start so agian do ecu learn & with xml file options / after sales ecu paring with 16 dighit pin than do vin write than with launch online confugration data transfer send ok than car start perfect but all do with my working car BCM / KEY so my another set need to BCM VERGIN & code but in this process i not success & i try but ECU CODING SUCCESS thanks all of u for help Ссылка на комментарий Поделиться на другие сайты Поделиться
rinaprasant 257 Опубликовано 21 апреля, 2022 Автор Поделиться Опубликовано 21 апреля, 2022 hello my 4 duster ph2 patrol done thanks to all fo you but now 2 captur with HFM module with jonshon control spc5605 mcu but if i try with renolink , when pin red no data message & if i try with UCH T4 than erpprom need to unlock please unable it , is any one help me thanks topic closed Ссылка на комментарий Поделиться на другие сайты Поделиться
