Keygen v2017.01 vFinaL.exe Analysis
valerysntx
1617101404_code4binestimatedlicensecost200eur.png.1e97555b7c7eed329d4937dab0088a02.png
 We see that we are lack of license. What is the problem, Lets' chat to code4bin@gmail.com!
Mr. code4bin doesn't wan't You to make free activations around the globe,
He will sell you missing parts of the application for around ~250$ 😕
 Paying attention to not send him bucks, why his app isn't cheap, let's see what we are missing ...
See, the missing part is the License.dat file, with 1.aes file packed inside, - it's a ZIP, let's fake it !
401618842_keygenwantszipwith1.aesinside.thumb.png.c73da63b5ba53dd02eb23a8f712c4636.png
Cool, let's dig it further, few steps for free activations, as it should be...
Computer binary mess, we get own Response.xml after digging inside 2,13.3 code,
Stop the growing corruption that started from '2.13.3 app + keygen' pack which was absolutely free lead to such noncense with versions, upgrades,
Let's stop manual <Request></Response >, transactions , forum spam for asking activations or license generator missing parts,
Fu*Kc You, no-named 'Key Generator Boss'
Keygen 2017.01 vFiNaL.exe.7z
License.dat to play around...
Does anybody has lic.ac file? ;)
License.dat
// 2017.x vFinal appbase
    private static byte[] EncryptInitStringForSecurityDLL(string initString)
      byte[] bytes = Encoding.UTF8.GetBytes(initString);
      byte[] rgbKey = new byte[24];
      string str1 = "Security.1;a<3k9Zvt^dE80";
      string str2 = "a2H*b#I'";
      for (int index = 0; index < rgbKey.Length; ++index)
        rgbKey[index] = Convert.ToByte(str1[index]);
      byte[] rgbIV = new byte[8];
      for (int index = 0; index < rgbIV.Length; ++index)
        rgbIV[index] = Convert.ToByte(str2[index]);
      ICryptoTransform encryptor = new TripleDESCryptoServiceProvider().CreateEncryptor(rgbKey, rgbIV);
      try
        using (MemoryStream memoryStream = new MemoryStream())
          using (CryptoStream cryptoStream = new CryptoStream((Stream) memoryStream, encryptor, CryptoStreamMode.Write))
            cryptoStream.Write(bytes, 0, bytes.Length);
            cryptoStream.FlushFinalBlock();
            return memoryStream.ToArray();
      catch (CryptographicException ex)
        return (byte[]) null;
   /*  Learn how it unpacks... */
    private static void FirstTimeSetup()
      SettingsHandler instance = SettingsHandler.GetInstance();
      if (instance.Program.ForceRegenerateX)
        string path = Path.Combine(SettingsHandler.GetDataFolder(), "x.sdf");
        if (File.Exists(path))
          File.Delete(path);
        instance.Program.ForceRegenerateX = false;
      bool flag = Program.IsFirstTimeSetupNeeded();
      CSDebug.WriteTrace("isFirstTimeSetupNeeded=" + flag.ToString());
      if (flag)
        Program.fs.Hide();
        int num = (int) new FormFirstTimeSetup(Program.versionString).ShowDialog();
        string[] contents = new string[2]
          Program.versionString,
          DateTime.Now.ToShortDateString() + " " + DateTime.Now.ToLongTimeString()
        File.WriteAllLines(Path.Combine(SettingsHandler.GetDataFolder(), "version.txt"), contents);
        Program.ApplyAccessRules();
      if ((!Program.IsRegLinkInstalled() || !flag ? (!Program.IsFirstTimeSetupNeededForRegLink() ? 1 : 0) : 0) == 0)
        int num1 = (int) new FormFirstTimeSetup(Program.versionString)
          RegLinkMode = true
        }.ShowDialog();
      if (Program.IsAdministrator())
        CSDebug.WriteTrace("Account running Main.exe is administrator. Applying access rules...");
      Program.fs.Show();
Program.cs
Here is the proof - 2.13 with the 2.17.1 missing db
Этот кейген уже отломали, так что не нужно попусту тратить время, тем более софт кривой...
22 часа назад, vargab сказал:
Мне тоже было бы интересно.
Я также хотел бы знать
password: final2017
В 01.02.2021 в 15:31, valerysntx сказал:
License.dat
