mitsubişhi colt amt problem
twister1974
Hi
yesterady during the transmission adaptation I got error message, after that the car don't start, not even cranck.
Fault code: 2724 Transmission adaptation: Implausible transmission adaptation data during the internal test
I can not erase this code.
I try adaptation again, it was OK, but code stays and car wont start.
Description of error ba MB star:
"Transmission adaptation: Control unit EEPROM error
The fault my occur durint transmission adaptation if brek pedal not applied
Possible cause and remedy:
Carry out transmission adaptation
Erase fault code
Switch off ignition
If the fault code reoccurs, replace control unit N3/9 (EDG control unit)"
Is it possible to erase this error from EEPROM or something else to do?
The break pedal was pressed during the test, ECu is comucating with diag tool...
Thank you.
