airbag 51918197 punto evo
abbate22
Help --- I changed the ecu airbag, I loaded the original firmware, it worked one day and only turned on red light. errors b0100 - internal control unit error, red light on. Seat belts and passenger airbags operated unlit. b1052 - airbag node FIS inertial switch control. b10aa - PROXY configuration check.
Dump pleass. And you mast have fiatecuscan tool for proxy procedur by obd
Geev mee dump
  • _____ закрыл тема
